Originally Posted By: simple_gifts
Some people have had good luck with autorx (like myself), others not. I believe there is a thread from dnewton where he got before and after compression readings and it certainly improved the #s.
I've taken aspirin to relieve a headache and it hasn't worked; that certainly doesn't disqualify it as a pain reliever when others ask for a recommendation.
You want compression readings) I can give all you want, how much of a difference would you like?
Don't ask me for proof. If thats the case show me his or are only certain people held to different standards?
Show me them on a recording compression tester if you want them to have any merit. I don't care who did it, if its not recorded by the actual tester its worthless.
No offense to you some people want to believe, show me the paper or lets stop the trash talk.
Lets see one done with this tool (or similar) and we can talk about compression reading results.
These testers are accepted by BMW, Mercedes, VW/Audi/Porsche, Dekra, TÜV, etc as proof for warranty work needed or completed repairs and are calibrated before use.
The card must be attached to the RO or they treat it as no proof provided. New cars use different methods also but this is the old standby.
http://www.motometer.de/recording-compression-tester.html
