friendly_jacek
Thread starter
Originally Posted By: freak007
Originally Posted By: friendly_jacek
BTW, this is the Mercruiser GM 4.0L 135 engine. Always hard to start since the day one.
I am guessing since you said 4 cyl that 4.0 is a typo.
the 3.0 is a 135hp GM industrial 4 cyl. Was also used in many forklifts.
If it has always been hard starting, I would go through the carb and verify the ignition timing. All of my carbureted engines will start in 1-2 pumps unless they have been sitting for 4-6 months. I have a restaurant style condiment bottle special for the times that they set for an extended period, a little squirt of gasoline into the carb and they are off... It may take you half a day to get it dialed in, but that half a day will greatly reduce your headaches later on.
Does yours have points, or electronic ignition?
My bad, I meant 3.0L (but 4-cyllinders).
It has electronic ignition. I was actually impressed how the engine was running OK (with the new plugs) with sparking coil.
Maybe the flooded plugs damaged the coil too?
I'm so glad I didn't crank it with plugs out as gasoline would shot out of holes right on the sparking coil. That would be some nice inferno.
