Oil suggestion for 2013 Honda CR-V
by Mar57
16 minutes 49 seconds ago
STOP CALLING ME!!!!
by NHHEMI
45 minutes 16 seconds ago
Need oil suggestion for high mileage 2003 WRX
by xmakeafistx
Today at 01:09 PM
09 VW Passat Wagon 2.0TSI 4900mi Castrol 0w40 Euro
by gerkin85
Today at 12:48 PM
Oil/filter recommendation for short trips
by DrRoughneck
Today at 12:46 PM
Auto Zone brand oil on clearance (YMMV)
by blupupher
Today at 11:20 AM
M1 5w30 HM / 5512 Miles / Turbo with Towing
by Astro_Guy
Today at 11:10 AM
My 2003 Dodge Dakota
by HM12460
Today at 08:37 AM
Check out the head off my extreme oil burner Honda
by Gasbuggy
Today at 01:31 AM
Unused Bosch 3313 cartridge
by Run
Yesterday at 11:14 PM
David Fry in his own words
by Merkava_4
Yesterday at 11:02 PM
Schaeffer 711 10w30 Detroit 60 12.7
by TiredTrucker
Yesterday at 09:17 PM
slewman, lithium1189, Monktana, djh3, Compignite
56850 Registered Users
94 registered (2oldtommy, 440Magnum, adelody, 05LGTLtd, 2015_PSD, 12 invisible), 1807 Guests and 200 Spiders online.
56850 Members
66 Forums
244408 Topics
Page 1 of 2 1 2 >
#3411549 - 07/01/14 10:18 AM Oil Pressure Question ... is my engine dead?
rc84 Offline
Loc: France
Hi,
The oil warning (pressure warning) light flickered when coming to a stop and with engine idling after a period of highway driving. Oil was only 5k km old and is the correct spec fully synthetic (5w-30 and matching all the manufacturers requirements) etc. Level is OK.
So checked the pressures using a plug-in gauge:
cold
@idle 1.75 bar = 25 psi
@2000 3.25 bar = 47 psi
hot
@idle 0.25 bar = 4 psi
@2000 1.5 bar = 22 psi
Replaced oil and filters and re-measured, so cold is while the engine is still warm but with fresh oil in
warm
@idle 1 bar = 15 psi
@2000 2.2 bar = 32 psi
hot
@idle 0.5 bar = 7 psi
@2000 0.75 bar = 25 psi
Tested the next day, so engine really cold again
cold
@2000 4 bar = 58 psi
So, need some advice now on interpreting these numbers. When cold the figures are all within engine specifications. Hot, they are too low.
There is no undue noise from the engine, except for the top-end tappets when idling, which I would expect with such low pressures, so I am hopeful that it is not bottom-end problems.
The oil pickup was replaced ~40k kms before and I assume that because the pressure is OK when cold then this is not causing the problem.
Does this imply that the engine is dead (main bearings worn) or that perhaps the oil pump is worn, or better still there is just a sticking pressure relief valve somewhere?
Any advice what to check / do next? Oil pump is a pig to get at behind cambelt etc, so not a quick job to pull off and check.
Many thanks
#3411561 - 07/01/14 10:30 AM Re: Oil Pressure Question ... is my engine dead? [Re: rc84]
GutsyGecko Offline
Loc: Youngstown, OH
Sounds like one of the two things you mentioned or more than likely a combination. What engine and mileage? Perhaps go to a 40wt oil and see if you get adequate pressure until you have another problem that leads you to removing things that will make it easier to take a look.
#3411562 - 07/01/14 10:30 AM Re: Oil Pressure Question ... is my engine dead? [Re: rc84]
vintageant Offline
Loc: Florida, USA
Need to know year, make, model and # of kms on engine before giving any opinions.
1925 Alvis HDEO 15W40
1937 Alvis Speed 25 HDEO 15W40
1970 VW Peking to Paris Rally Beetle HDEO 15W40 w LM Ceratec
2003 Honda Accord dino 5W20
#3411595 - 07/01/14 10:57 AM Re: Oil Pressure Question ... is my engine dead? [Re: vintageant]
rc84 Offline
Loc: France
It is Volvo V50 1.6d (110hp) with 210k kms.
#3411609 - 07/01/14 11:05 AM Re: Oil Pressure Question ... is my engine dead? [Re: rc84]
expat Offline
Loc: Canada
Back in the Bad old Days a situation like this would just mean I would start using progressively heavier oil.
I remember on one car, a Sunbeam Stilleto, I was running 20w-50 AND STP oil treatment.
I put several thousand miles on that car before it went to the wreckers yard.
#3411654 - 07/01/14 12:00 PM Re: Oil Pressure Question ... is my engine dead? [Re: rc84]
Shannow Online   content
Loc: Oz
The turbine engineer in me says to check the instrumentation first...i.e. pressure sender.
If you have both a switch AND a pressure sender, then you probably have a genuine pressure problem. If the switch is computed off the sender, I'd swap senders just to check.
#3411665 - 07/01/14 12:11 PM Re: Oil Pressure Question ... is my engine dead? [Re: rc84]
rjundi Offline
Loc: USA
The definitive test is using a mechanical oil pressure guage and then move forward.
#3411677 - 07/01/14 12:44 PM Re: Oil Pressure Question ... is my engine dead? [Re: rjundi]
heynow Offline
Loc: Nevada
1991 Acura NSX
1991 Suzuki Samurai
#3411737 - 07/01/14 02:05 PM Re: Oil Pressure Question ... is my engine dead? [Re: rc84]
Donald Offline
Loc: Upstate NY
I had a voltmeter in my Bobcat that would never show more than 12V with engine running. I brought the alternator to a rebuild shop and they said it was fine. I could not test it with a DVM as the Bobcat would "creep" down the drive if I was not in the cab. Finally got a chance to test it with DVM with someone else in the cab. It was fine.
There was buildup of sawdust in all gauges and the voltmeter could not go past 12V.
2015 Subaru Forester 2.5 engine/CVT PP & M1
2001 Jeep Grand Cherokee Laredo 4.0 - PP & M1
1999 Dodge Ram 2500 w/Cummins - Rotella T6 & M1
#3411754 - 07/01/14 02:29 PM Re: Oil Pressure Question ... is my engine dead? [Re: rc84]
Chris142 Offline
Loc: apple valley, ca
cold oil pressure means nothing so stop posting that info. 4 psi is a little low assuming its idling at around 700 rpm. id bump it up to thicker oil and drive it till it dies.
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#3411803 - 07/01/14 03:59 PM Re: Oil Pressure Question ... is my engine dead? [Re: rc84]
spasm3 Offline
Loc: out there
If the 4 psi is correct( like Shannow suggested, a real gauge, not a reading of the current sender.) then the main bearings may be worn. A thicker oil is what i would do. The old rule is 10 psi per thousand rpm. I don't think that works for newer variable displacement oil pumps. Perhaps a 0w 40 would do better.
Edited by spasm3 (07/01/14 04:00 PM)
13 elantra 39k 5w30 ultra
03 chevy avalanche64k pyb
02 saturnsc1 62k 0w40 castrol
01 saturnsc1 185k being rebuilt
93 ciera 71k 5w30mc5k
#3411831 - 07/01/14 04:36 PM Re: Oil Pressure Question ... is my engine dead? [Re: rc84]
bigjl Offline
Loc: London, England
I had a mk1 Focus estate tddi with the old 1.8 turbo lump
The oil pump was so worn the oil light would come on at tickover when hot, as soon as you raised the revs it went off.
I did 10k miles like this, with the precaution of keeping the revs above tickover when stationary.
Sold the car with mega miles on it via eBay, advised the new buyer about the oil pressure issue, he changed the pump and it was fine from then on.
It is possible to use a thicker oil I suspect.
Though from my research the 1.6d is specced for 5w30 in all makes it is fitted to.
I would be looking at getting the sump off and making sure the pickup is clear and changing the oil pump regardless of how hard it is to do.
Why was the pickup changed?
Was it blocked?
If it blocked once it could block again.
Edited by bigjl (07/01/14 04:38 PM)
10 BMW 116D SE 110k miles Full BMW Hx
12 Jaguar XJL 3.0 D Luxury 132k 5w30 Shell AF-L
#3411844 - 07/01/14 04:58 PM Re: Oil Pressure Question ... is my engine dead? [Re: rc84]
Kiwi_ME Offline
Loc: New Zealand
I would do anything. Thicker oil may give you a higher idle pressure and turn the light but that doesn't mean you get more flow.
Decades ago I drove an old Skoda with a completely worn bottom end around for months with no measurable hot oil pressure and it didn't stop running. Only the annoying vibration made me fix it.
#3412022 - 07/01/14 09:02 PM Re: Oil Pressure Question ... is my engine dead? [Re: rc84]
artificialist Offline
Loc: Florida
I once encountered an engine that triggered the low oil pressure light without having bearing clearance problems. The customer had a turbocharged Chrysler PT Cruiser, and overheated the engine. By the time the owner stopped at our repair shop, the oil light was on, even there was no bearing noise or lash adjuster tick. Once we repaired the cooling system, the light never came back on.
Do you know exactly what your engine coolant temperature is? Coolant temp sensors often fail without causing an error code. That is because they can fail by displaying a normal engine temperature, instead of having too little or too much resistance to clearly cause an error code.
Since there is usually one temperature sensor, there may be parts of the engine that heat up differently. This often happens when a plastic water pump impeller cracks, or if air bubbles are trapped in the cooling system.
2010 Lancer Ralliart Sportback
#3412395 - 07/02/14 09:53 AM Re: Oil Pressure Question ... is my engine dead? [Re: rc84]
vintageant Offline
Loc: Florida, USA
If it were mine, I'd change to a diesel oil, such as Shell Rotella 15W40, to test and measure.
Page 1 of 2 1 2 >
