knowing that modern vehicles using crazy 0w20 and such are designed to use it, can one assume motors of the 80's to late 90's (or the designs ) can runn thinner oils available now since they are said to be stronger?
on this website ive seen a lot of people substitute 5w30 for 10w30 on an 1985 motor (example) or using 1030 instead of 30 wt.
i have 3 vehicles needing Xw30 oil. one needing 530,the other is 30, the other says 1030.
if i live in an area where morning temp is 80degrees and motorcycles in the sun show 125*f oil temps on the dipsticks at 1pm in the afternoon could i run 1030 in everything ?
im sure im gonna get guff for (use what oem calls for) but im just curious
