I did the 90k mile service on our 2008 CR-V this weekend. I thought that I had an A02 on it, but it was a PureONE PL14610. Of course, I cut it open. The last Purolator filter I posted looked so good after 3k miles, it was questioned how a used filter looked so dry. So this time, I took pictures wet to demonstrate that it was, in fact used...used on an '08 CR-V for 5k miles with Havoline 5W-20 oil.
As with the Classic L14610 I ran 3k miles on our Acura, this filter looks to be in very good condition with only slightly waving pleats near the metal crimp. All other media pleats look very uniform, so I just took a photo at the crimp. No apparent malfunctions.
The date code is F07B13E1. Manufactured on July 13, 2010, on line E, shift 1, in the Fayetteville, NC, facility. I have three more with the same date code, and I'll continue to use them. I mistakenly told david1 that I had an A02 to cut open for him, but this is that filter instead. So I installed one of my A02s this weekend just for you, david1!
I'll check back in 5k more miles.
The guts:
The glory:
The guts:
The glory:
