Oil Infatuation
by Passport1
07/30/16 03:43 PM
FREE T-SHIRT, $10, AND GOD KNOWS WHAT ELSE....
by macarose
07/30/16 03:16 PM
Griot's Brilliant Finish Carwash
by SavagePatch
07/30/16 02:25 PM
Hanging 3rd - Honda Automatic
by RevelationLion
07/30/16 01:31 PM
Oil Interval Mountain Driving Road Trip
by Yup
07/30/16 12:58 PM
Giant VW Beetle....
by mattwithcats
07/30/16 12:43 PM
anyone have the 12 ton HF press?
by joel95ex
07/30/16 12:27 PM
BMW final drive 75W90 GL5. Supertech semisyn OK?
by David_g
07/30/16 12:00 PM
Shuffle your feet!
by Stelth
07/30/16 11:44 AM
BMW Hexhead gearbox oil? Redline shockproof?
by David_g
07/30/16 11:11 AM
Meg's Ultimate vs Collinite 845/476s?
by MisterBen
07/30/16 10:17 AM
Why do factory filters get such a bad rep?
by MisterBen
07/30/16 10:09 AM
kenb777, Indyfan3, RM53119, Ctanke, jractk
58649 Registered Users
65 registered (2010Civic, AIRJAC3, 65convertible, 07Piloteer, 97f150, 04SE, 6 invisible), 2053 Guests and 5 Spiders online.
58649 Members
66 Forums
252451 Topics
#3407761 - 06/26/14 03:55 PM TBN methodology changing at Blackstone
Kristin Huff Offline
Loc: Ft. Wayne, IN
Dear BITOG Members: We wanted to let you know that we are changing our TBN testing process slightly. We have always run a modified version of ASTM D-4739, but our machine was calibrated using standards that more closely matched to ASTM D-2896. We are now moving to standards that are more closely aligned with D-4739 and the only difference we have noticed is a slight drop in virgin oil TBN readings. The used oil TBN readings are not expected to change much at all, but virgin oils will tend to read a little lower. ASTM D-2896 is a method used by oil companies to provide TBN readings for their virgin product. It uses stronger acids than ASTM D-4739, so it tends to give higher readings. Since we mostly see used oil, we picked ASTM D-4739 as our method of choice, and this change in standards should give us more consistent readings. (ASTM methods are generally available at your local library at no change if you want to see the actual method.)
Because BITOG members tend to watch virgin TBN readings closely, we wanted to let you know about this change. And to help smooth out the transition, we will also be willing to run any samples you wish under both methods so you can see for yourself what type of differences occur. If you want to take advantage of this, just send in your sample and ask for both TBN methods on the oil information slip. Feel free to contact me with any questions you might have.
Sincerely,
Ryan Stark
Blackstone Laboratories Inc.
260-744-2380
#3407773 - 06/26/14 04:15 PM Re: TBN methodology changing at Blackstone [Re: Kristin Huff]
tinmanSC Offline
Loc: Oswego, IL
umm... awesome, I guess? Will continue to send samples in!
Cost of Hobby=2L
(Where L=Cost of Lubricant)
95 Lexus SC300 [email protected], 2000 [email protected] both VML Full Syn+Purolator PSL20195(soon to be Wix)
#3407778 - 06/26/14 04:24 PM Re: TBN methodology changing at Blackstone [Re: Kristin Huff]
OneEyeJack Offline
Loc: S California
As long as the TBN is close, the trend would be what I'm interested in for any particular vehicle.
#3407809 - 06/26/14 05:12 PM Re: TBN methodology changing at Blackstone [Re: Kristin Huff]
Kuato Offline
Loc: In transit...
This should be stickied so everyone can see it.
Ryan/Kristen, do you have an approximate difference in initial TBN between the two methids?
Your oil's condition is speculation until you get a UOA done.
2013 F150, 5.0 4x4, 52k Schaeffer 9000
#3407827 - 06/26/14 05:55 PM Re: TBN methodology changing at Blackstone [Re: Kristin Huff]
yvon_la Offline
Loc: quebec canada
Ty blackstone for going to this trouble in the name of real world accuracy.awsome job!this will likely give more accurate result for used oil analysis comparo .since thw other way differed slightly
Truck driver
Nissan versa note s 2014 Mobil Delvac 1 LE 5W-30 supertech st-6607(edition 2016) castrol transynd
#3411068 - 06/30/14 04:35 PM Re: TBN methodology changing at Blackstone [Re: Kuato]
Loc: Ft. Wayne, IN
Sorry about the delay in getting back to your question. I believe the new TBN method will give results that are 25% lower than our old method.
Sincerely,
Ryan Stark
Blackstone Labs
