Round holes AND louvers! Oh the humanity!
by Nick1994
35 minutes 28 seconds ago
Should I change the oil when changing spark plugs?
by THafeez
47 minutes 37 seconds ago
Maxima synthetic oil
by gman2304
53 minutes 10 seconds ago
Mobil vs. Castrol: Battle of the Walmart 0W-40s
by 1JZ_E46
56 minutes 55 seconds ago
Need advice for older car burning too much oil
by Car_Careguy
Today at 03:29 PM
Camaro 2.0T review by subaruwrxfan
by wemay
Today at 03:18 PM
Dryer Duct Boosters?
by 2015_PSD
Today at 03:02 PM
some strange lawsuits against fast food franchises
by John_Conrad
Today at 02:40 PM
Rotella T5 10W-30 in Chevy Z71
by RHALL
Today at 02:20 PM
Multigrade Oils in Mowers
by camrydriver111
Today at 01:59 PM
Is this GM executive serious ? Or he's a moron ?
by HTSS_TR
Today at 01:40 PM
My UOA with Frantz TP Filter
by Jonzobot
Today at 12:43 PM
ryaneirich, Gabe78, taters, Louis_Desbiens, Burk
58918 Registered Users
89 registered (97f150, 1JZ_E46, 007, 2015_PSD, 390pi, addyguy, 9 invisible), 1860 Guests and 5 Spiders online.
58918 Members
66 Forums
253549 Topics
#3410333 - 06/29/14 08:29 PM engine heats up a little in outside high temp
peh43 Offline
Loc: Florida, USA
I have a 2004 Chevy Express 3500. When the temperature outside gets to 90 or higher, the engine heats up a little while running the A/C. Sometimes it might get to one mark above 210 on the gauge and will drop after driving 2 to 5 miles. I had to replace the water pump about 3 years ago and flushed out last year. When not running the A/C not a problem with the heating up. Is this normal running the A/C during the hot weather? The van has 205K miles. Any comments.
#3410340 - 06/29/14 08:39 PM Re: engine heats up a little in outside high temp [Re: peh43]
skyactiv Online   content
Loc: The Midwest
With 205K, I imagine the fan clutch has seen better days. Does your van run hotter than it use to while idling in traffic at such temps?
Me: 13' VW GTI 3 door 6 speed manual
#3410343 - 06/29/14 08:42 PM Re: engine heats up a little in outside high temp [Re: peh43]
CapitalTruck Offline
Loc: Washington, DC
Something is a little off there. 210 is in the high normal range. I'm assuming that you're saying that when on the move the temperature will drop, but when you're idling that it will go up. One suggestion: I know my 2004 Silverado had a mechanical, belt driven fan with fan clutch. It's possible that the fan clutch is starting to go and not spinning the fan FAST ENOUGH at idle. It might be spinning it some, but not fast enough to meet spec. That might be worth looking into (all of that is out the window if your Express has electric fans). Also, it might be worth taking a garden hose, opening the hood, and spraying the radiator off from the inside out to get rid of bugs and debris. You'll be really surprise how much junk comes out of there, even if it doesn't look like a lot. These are some simple steps, but sometimes they are the ones that do it. I will say that my 2004, even in perfect running order, heated up running the A/C in Winslow AZ while sitting still at a post office. It was about 105 or so at the time.
2013 Silverado 4.8L VVT 4x4 70k mi - Mobil 1 5w30, Mobil 1 M1-113/ACDelco UPF48R oil filter
#3410360 - 06/29/14 08:57 PM Re: engine heats up a little in outside high temp [Re: skyactiv]
Loc: Washington, DC
Looks like we were thinking the same thing at the same time. Good minds...
#3410364 - 06/29/14 09:01 PM Re: engine heats up a little in outside high temp [Re: skyactiv]
peh43 Offline
Loc: Florida, USA
Yes, it does heat up some while idling in traffic. I did have the fan clutch replaced about 4 years ago. I would think they would last longer 4 years.
Edited by peh43 (06/29/14 09:03 PM)
#3410373 - 06/29/14 09:08 PM Re: engine heats up a little in outside high temp [Re: CapitalTruck]
peh43 Offline
Loc: Florida, USA
I will give that a try taking the garden hose to the radiator.
#3410483 - 06/29/14 11:18 PM Re: engine heats up a little in outside high temp [Re: peh43]
Chris142 Offline
Loc: apple valley, ca
Not if it was an aftermarket. The dealer one...Maybe.
02 Wrangler Chevron 10w30
87 F250 napa 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#3410522 - 06/30/14 12:37 AM Re: engine heats up a little in outside high temp [Re: peh43]
andyd Offline
Loc: Marshfield , MA
Does this have an electric fan that kicks in when the AC is on? If so, is it coming on?
1988 BMW 528e 20w50 dino, STP filter
'09 Camry SE, Valvoline bulk 5w30 and ? filter
#3458319 - 08/17/14 10:07 PM Re: engine heats up a little in outside high temp [Re: peh43]
Greasymechtech Offline
Loc: Paradise of Florida
Also check coolant level. Replace rad cap and thermostat.
At what point should a lurker start posting :-)
