Cut Super Tech ST3980 2500miles
by jhellwig
05/29/16 12:25 AM
Smoked my first brisket today
by MrHorspwer
05/28/16 11:00 PM
Lowes charcoal sale
by Bandito440
05/28/16 10:17 PM
Jeepers Creepers! (Jeep Patriot)
by daves87rs
05/28/16 10:10 PM
Need a tire
by Leo99
05/28/16 09:58 PM
Small Engine Oil Pressure
by funflyer
05/28/16 09:06 PM
Any harm in using a Motorcraft FL910S on a Tacoma?
by jongies3
05/28/16 08:50 PM
A/C performance woes...
by SEMI_287
05/28/16 08:49 PM
Red Line 10W30 Motorcycle oil particle count
by bulwnkl
05/28/16 08:08 PM
Microgard 51334 cut open
by dlundblad
05/28/16 08:07 PM
Differential Fluid Selection..
by Warstud
05/28/16 07:13 PM
The morality of riding a bike married with kids
by fdcg27
05/28/16 07:00 PM
mungchimp, troutwest66, AIRJAC3, bpete65, LEVY
58001 Registered Users
20 registered (Duffyjr, c502cid, bbhero, Duke, 2 invisible), 459 Guests and 102 Spiders online.
58001 Members
66 Forums
249545 Topics
#3410333 - 06/29/14 08:29 PM engine heats up a little in outside high temp
peh43 Offline
Loc: Florida, USA
I have a 2004 Chevy Express 3500. When the temperature outside gets to 90 or higher, the engine heats up a little while running the A/C. Sometimes it might get to one mark above 210 on the gauge and will drop after driving 2 to 5 miles. I had to replace the water pump about 3 years ago and flushed out last year. When not running the A/C not a problem with the heating up. Is this normal running the A/C during the hot weather? The van has 205K miles. Any comments.
#3410340 - 06/29/14 08:39 PM Re: engine heats up a little in outside high temp [Re: peh43]
skyactiv Offline
Loc: The Midwest
With 205K, I imagine the fan clutch has seen better days. Does your van run hotter than it use to while idling in traffic at such temps?
Me: 13' VW GTI 3 door 6 speed manual
#3410343 - 06/29/14 08:42 PM Re: engine heats up a little in outside high temp [Re: peh43]
CapitalTruck Offline
Loc: Washington, DC
Something is a little off there. 210 is in the high normal range. I'm assuming that you're saying that when on the move the temperature will drop, but when you're idling that it will go up. One suggestion: I know my 2004 Silverado had a mechanical, belt driven fan with fan clutch. It's possible that the fan clutch is starting to go and not spinning the fan FAST ENOUGH at idle. It might be spinning it some, but not fast enough to meet spec. That might be worth looking into (all of that is out the window if your Express has electric fans). Also, it might be worth taking a garden hose, opening the hood, and spraying the radiator off from the inside out to get rid of bugs and debris. You'll be really surprise how much junk comes out of there, even if it doesn't look like a lot. These are some simple steps, but sometimes they are the ones that do it. I will say that my 2004, even in perfect running order, heated up running the A/C in Winslow AZ while sitting still at a post office. It was about 105 or so at the time.
2013 Silverado 4.8L VVT 4x4 70k mi - Mobil 1 5w30, Mobil 1 M1-113/ACDelco UPF48R oil filter
#3410360 - 06/29/14 08:57 PM Re: engine heats up a little in outside high temp [Re: skyactiv]
Loc: Washington, DC
Looks like we were thinking the same thing at the same time. Good minds...
#3410364 - 06/29/14 09:01 PM Re: engine heats up a little in outside high temp [Re: skyactiv]
peh43 Offline
Loc: Florida, USA
Yes, it does heat up some while idling in traffic. I did have the fan clutch replaced about 4 years ago. I would think they would last longer 4 years.
Edited by peh43 (06/29/14 09:03 PM)
#3410373 - 06/29/14 09:08 PM Re: engine heats up a little in outside high temp [Re: CapitalTruck]
peh43 Offline
Loc: Florida, USA
I will give that a try taking the garden hose to the radiator.
#3410483 - 06/29/14 11:18 PM Re: engine heats up a little in outside high temp [Re: peh43]
Chris142 Offline
Loc: apple valley, ca
Not if it was an aftermarket. The dealer one...Maybe.
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#3410522 - 06/30/14 12:37 AM Re: engine heats up a little in outside high temp [Re: peh43]
andyd Offline
Loc: Marshfield , MA
Does this have an electric fan that kicks in when the AC is on? If so, is it coming on?
1988 BMW 528e 20w50 dino, STP filter
'09 Camry SE, Valvoline bulk 5w30 and ? filter
#3458319 - 08/17/14 10:07 PM Re: engine heats up a little in outside high temp [Re: peh43]
Greasymechtech Offline
Loc: Paradise of Florida
Also check coolant level. Replace rad cap and thermostat.
At what point should a lurker start posting :-)
