I know that you can make "performance" upgrades to a Diesel to make it smoke, but, in a stock car, what system or parts need to fail or be under-serviced to make it smoke??
I ask this because I was in a shop because of a broken wheel and while I was waiting, a costumer came to pick up his car, a MKV Jetta TDI, apparently they perform a full service on his car (oil, filter, air filter, fuel filter, clean injectors and what not), then the costumer asked about the smoke issue an the technician said: "That is completely normal, because it is a Diesel, and because of the high mileage of your car, soon we will have to rebuild your engine but since it still develops plenty of power we can wait a little longer" . Then the costumer asked if the smoke will stop when the engine is rebuilt and he said: "It will be less but it will still produce smoke because the Diesel engine operates in that way"
I chatted a little bit with the costumer, saying that I wanted to buy a car like that and other trivial things, just to take a look at the odometer. The car only had 115,000 km!!!
Then the costumer departed and sure enough a little cloud of smoke came out of the tailpipe. I expected the smoke to be blue, as if the engine was burning oil, as the technician had implied earlier; but the smoke was black and smelled like diesel.
I don't think these cars had a DPF but I am sure it should not be smoking like that. So why an apparently "serviced" car with low mileage and without tuning modifications produces smoke like that??? Are these engines computer controlled, with an oxygen sensor or some other type of sensor, like a fuel injected engine or they use a mechanical open loop system like a carburetor??
