Originally Posted By: ram_man
My 02 sl is a manual trans and tonight all the way to where I was going at a stop it would Odle around 1500rpm. Shutting off and restarting did cure it temporarily. But it came back then 35 more miles of driving and didn't do it once . Acts perfect again. I know usually it would be a tps but I did replace it about 4 months ago. No cel or anything like that
IAC valve, for starters. And clean the throttle body. Check for exhaust leaks. There is tons of info on high idle at saturnfans.
When I got my SL1 auto, the idle would spike now and then at startup or at stoplights. Also it had the shakes, a bit. Here is what I did or had done:
clean throttle body
tps sensor
iac valve
ects
thermostat
Motor mount (OE solid mount 21012185)
flex pipe---repair exhaust leak
air filter
spark plugs: ngk copper/nickel, BKR4ESA-11
Now all is smooth and well....good luck.
