Honda? Ignition switch? It is most likely under safety recall campaign. If it was replaced before, most likely it is going again. You probably have 3 pounds of keys hanging off that key-chain which is not helping.
Most likely causes for a circa 2000 Honda:-
1)Ignition Switch (electrical part)
2)Main relay under the dash
If the 1st does not fix it, go after the 2nd one.
