Have you ever snapped a grease zerk off when installing it? This one here is a 6mm x 1.0mm grease zirk. It was going in real hard with a nut driver, so I decided to use a 1/4 inch drive ratchet with an 8mm socket to turn it in. Just before it was fully seated, it snapped. I was half way into replacing the lower control arms when I had to abort the mission and go in reverse. Got the old lower control arms back on. I'm pretty angry with myself right now fellas, but I thought I'd risk the embarrassment of posting this in hopes of somebody out there may have the perfect solution.
