Update: I got sick of waiting and after reading the warranty certificate, realized they most likely will not cover it. So I went out and tried to get the nuts off of the studs. Two I got off with a little finagling, two refused to come off. Turns out the threads on the studs stripped where the nut threads on, not the threads in the crankcase. I managed to get the last two nuts off by dremeling and cracking them. Same thing, the threads on the studs stripped where the nut was. Have no idea how to get the studs out now to replace them. Service manager said they were threaded in, so they probably are red loctited in, so that means heat. Parts diagram doesn't show this are in detail so I have no idea. Replacing the studs would most likely require removing the clutch cover. Thinking of just bringing it in to the dealer to have them replace the stud, since I'm afraid of screwing something up.
