Why Measure Trans. Fluid with Engine Running?
by doitmyself
05/04/16 07:39 AM
Is Pennzoil discontinuing High Mileage 10W40?
by aquariuscsm
05/04/16 06:55 AM
Lowering vehicle with alternative coil springs
by OlDirty
05/04/16 06:22 AM
Remington R1 1911 or Springfield 1911-A1 MIL-SPEC
by MuzzleFlash40
05/04/16 06:02 AM
2017 Ford F150 3.5 EcoBoost
by DuckRyder
05/04/16 05:25 AM
Ford Powershift Gearbox Class Action (Oz)
by hpb
05/04/16 03:50 AM
Central Mississippi automotive goods
by mjoekingz28
05/04/16 02:11 AM
Free: 5 Quart jug Peak 5W-30
by Indyvwhonda
05/04/16 01:01 AM
Subaru Oil Burning Class Action
by Bandito440
05/03/16 11:43 PM
'01 Toyota 3.0: oil to clean up sludge?
by HawkeyeScott
05/03/16 11:06 PM
What is the purpose of a 4.4 litre oil container?
by vitez
05/03/16 10:56 PM
Cut Open: Nissan OEM, Bosch D3300 & Mobil M1-110
by davison0976
05/03/16 10:38 PM
Palmer, jessanmark16, danbee, PTT, greasy_knuckles5
57790 Registered Users
98 registered (ARCOgraphite, 2009Edge, 87sammy, 06AllAmerican, aquariuscsm, 2015_PSD, 9 invisible), 1412 Guests and 296 Spiders online.
57790 Members
66 Forums
248443 Topics
#3407242 - 06/26/14 03:06 AM Rimula r6 in MB Actros
chrisri Online   content
Loc: Fiume,Croatia,EU
Been talking with my old man and he just returned his company 06 Actros 1848 with 1300000 km on odometer.It had 80000 km OCI mostly with rimula r6.No problems whatsoever,original turbo etc. For replacement he got new IVECO Stralis HI WAY 500.What puzzles me is OCI on this one.It's 150000 km (93000 miles).Has engine and oil technology evolved this much in eight years?For sure it uses much less fuel then old Merc (31l/100km vs 36l/100km) and he sad it pulls better.Recommended oil for Stralis is Urania fe 5w30.
99 FIAT Punto Sporting 16v ( Shell Helix Ultra 5w40 )
06 FIAT Stilo MW 1.9 Multijet (Selenia WR 5w40)
#3407281 - 06/26/14 06:32 AM Re: Rimula r6 in MB Actros [Re: chrisri]
shDK Offline
Loc: Denmark
I would not drive The Oil for that Long. Especially when thinking off the massive problems Iveco has had with turbochargers.
#3407346 - 06/26/14 08:53 AM Re: Rimula r6 in MB Actros [Re: chrisri]
Neither would i but trucking companies will.It's probably not only Iveco thing,this long OCI,other manufacturer are most likely doing the same.It all comes down to the cost of maintenance during ownership of vehicle.And majority will make it to the 1000000 under 6 years easily.
#3411075 - 06/30/14 04:40 PM Re: Rimula r6 in MB Actros [Re: chrisri]
Doug Hillary Offline
Loc: Airlie Beach Australia
Hi,
chrisi - I used Delvac 1 5w-40 at an average of 80kkms OCIs in my vehicles for many years. This was in DD Series 60 500hp engines. A tear down-measure up on one at around 1.2m kms showed that all parts were within operating specifications. One engine at least went to 2m kms without a rebuild
I used a Mann-Hummel centrifuge and SS FF inserts - UOAs were used to monitor lubricant condition
UOAs and pictures of liners and bearings appear within BITOG
Regards
Doug
#3411453 - 07/01/14 08:06 AM Re: Rimula r6 in MB Actros [Re: Doug Hillary]
Hi Doug Hillary
80kkm OCI was industry standard for last IDK,ten,fifteen years and this works fine.This is not why i started this topic.Reason behind it is this new 150kkm interval.It almost double it. Can't see oils are this much better then few years before. Will this work? What do you think?
#3411786 - 07/01/14 03:31 PM Re: Rimula r6 in MB Actros [Re: chrisri]
Hi,
chrisri - The "Industry Standard" OCI for OTR trucks with American technology engines in "general" applications here is around 30kkms
In extending OCIs much depends on fuel quality/specification, lubricant standards and top up rate, filtration devices, combustion technologies, vehicle application and climatic conditions - and several other factors. This is why trended UOAs play such an important role in such practices as does extensive field testing
The OEM's lubricant condemnation levels and lubricant quality are important factors. For instance the OEM's max. soot level may be 2% but some lubricants will tolerate 6% with no adverse affects
To keep my reply short and having a good knowledge of MB and their practices (I worked for them and have been to Worth many times) I believe the 150kkms OCI is manageable!
Regards
Doug
