Lmao, you are arguing against yourself, not me.
Hydrogen as a motor fuel is a very good fuel, why would you think any different? Your only product of combustion is water vapor, it would be a very clean fuel. I have never said nor have I ever implied that it was "found not to work". Where have you ever seen that?
You do have a problem storing it though, since it is a gas (and cannot be liquefied at any reasonable pressure or temperature) then the volumetric efficiency is going to be low - as it is for any gaseous fuel. Liquid fuels are always going to have the advantage in that respect.
The most serious problem though is where are you going to get it? If you have a hydrogen well somewhere, like you have for natural gas then you might make a go of it. But making it from water using the vehicle's electrical system? That's where it all falls apart.
And yes fuel injection systems take energy but you get more efficient fuel consumption (not as much unburned hydrocarbon). But once again, you continue to confuse increasing the efficiency of an ICE (up to the Carnot limit) with this device. You're not gaining efficiency by adding a miniscule amount of hydrogen gas to the system, especially when your energy cost to produce the hydrogen is so onerous.
