I was using the Redline 5W-20 before they had the 0W-xx line.
Different vehicle than I have now.
Compared to Mobil 1 5W-20 at the time, the Redline was thicker at start-up in Cold Wisconsin winter as compared to the Mobil 1 5W-20.
This was noted by the slightly slower turn-over with the Redline vs Mobil 1.
NOTE that I am comparing the Mobil 1 from a few years ago.
CATERHAM's explanations in the past educated me as to why.
2 oils, same 5W-20, but we need to look beyond that, and beyond the HTHS.
Times change, products change, which is why we are here, to learn and adjust (if need be) to the new products and information available.
The question that I would like to add to the learing here.
In cold weather, short trips.
Which oil will have more resistance to the ill effects of fuel moisture, fuel dilution, and other things that take place in cold weather short trip driving?
While xW-40 is outside the specifications of my particular application, I don't want to off topic us from his application.
