Ugly New Prius #2
by AirgunSavant
08/28/16 08:32 AM
Getting hurt at work
by ram_man
08/28/16 04:46 AM
Brake Pad Shims a MUST?
by SavagePatch
08/28/16 01:34 AM
Bean Counters vs Swedish Engineering
by Y_K
08/28/16 12:04 AM
Interesting website for comparing guns
by 901Memphis
08/27/16 11:45 PM
Android clear cached data
by expat
08/27/16 11:07 PM
Worm gear vs spring type hose clamps?
by TheLoneRanger
08/27/16 10:35 PM
Factory fog lights...common wiring and wattage?
by ryan2022
08/27/16 10:32 PM
2 Hyundai/Kia OEM Filters cut open
by KD0AXS
08/27/16 10:30 PM
Preferred SUV for snow: Large FWD or smaller AWD?
by Carbon12
08/27/16 09:55 PM
Chevron 5W-20 $10/5-quart at WM
by wgtoys
08/27/16 09:15 PM
Best alternative to FL500S
by buck91
08/27/16 09:11 PM
DALpilotMike, Safetyfirst, rwood, USARMOR, GV00
58943 Registered Users
78 registered (4WD, 09_GXP, 2010Civic, 2015_PSD, 2009Edge, 2004tdigls, 5 invisible), 1310 Guests and 25 Spiders online.
58943 Members
66 Forums
253659 Topics
Page 3 of 3 < 1 2 3
#3403052 - 06/21/14 02:00 PM Re: is 0W-20 always better for mpg than 5W-20? [Re: yvon_la]
OVERKILL Offline
Loc: Ontario, Canada
Originally Posted By: yvon_la
Could any explain to me why the majority of car maker say to use
5wxx ?how come almost all car maker never say 0wxx .what is wron with a 0wxx oil?is it an issue in the dino version?
Because it requires a synthetic and is more expensive. OEM's that generally aren't German usually don't make it a policy to spec (expensive) synthetic oil.
02 Expedition
06 Charger R/T
14 Charger SRT-8
#3403068 - 06/21/14 02:31 PM Re: is 0W-20 always better for mpg than 5W-20? [Re: virginoil]
CATERHAM Offline
Loc: Burlington, Ontario, Canada
Originally Posted By: virginoil
Originally Posted By: CATERHAM
Jasper8146, as others have mentioned, your car is spec'd for the 5W-20 grade so in a warranty situation it is possible that you could be questioned as to why you're using a 0W-20.
Now if you're not concerned with that then yes you can use a 0W-20 and even the TGMO 0W-20 as a number of Hyundai/kia owners have with good UOA results. But be advised that TGMO is one of lightest 20 grade oils available so in your climate, since your car is not equipped with oil gauges to monitor things I'd suggest substituting a 1/2-1 quart of M1 0W-40 to give your a somewhat heavier 0W-20 oil. It will still be lighter on start-up than all 5W-20s and even most aftermarket 0W-20s, but it will retain a higher high temp' viscosity.
Why not promote the OP to find a ?w-20 oil with the appropriate builder approval. The OEM would quiver how freely it it is touted mix this with that to come up with what ?
Surely with the huge range oil of brands for selection in that grade you have in the USA, compared to OZ, there must be one on the shelf you can add with confidence in an unadulterated form straight out of the container.
Unbelievable from my view point in OZ.
Yes virtually every oil brand offers something in a 5W-20 and now the 0W-20 grade in NA but as I mentioned Hyundai/Kia don't spec' the 0W-20 grade just 5W-20.
The OP could use M1 0W-20 which Mobil states will not void any companies warranty when used when 5W-20 is specified but that's about it.
The OP inquired about using TGMO 0W-20 and is the reason for my response. If he was interested in something a bit heavier without blending, SynGard 0W-20 (220 VI, HTHSV 2.7cP) would be an option but it is not as readily available.
74 Lotus Europa, 5W-50
86 Porsche 928S, TGMO 0W-20 25% / M1 0W-40 75%
96 BMW 328i, Idemitsu/TGMO 0W-20 70% / M1 0W-40 30%
94 Caterham 7, FUCHS 0W-20
#3403541 - 06/22/14 06:02 AM Re: is 0W-20 always better for mpg than 5W-20? [Re: Jasper8146]
virginoil Offline
Loc: western australia
Caterham the vehicle in question is a 2014 under warranty it puzzles me why in this instance you promote a mix this and that to get who knows what.
If the OP is off the mark I would expect an experienced BITOGer to inform the OP to follow OEM directions.
This is my view, like you have yours, and the longer I spend on this forum I am seeing the OEMs perspective clearer and clearer.
Arriverdici e buona sera
#3403608 - 06/22/14 08:22 AM Re: is 0W-20 always better for mpg than 5W-20? [Re: Jasper8146]
Cujet Offline
Loc: Jupiter, Florida
I don't want to generalize with engines and climates I'm not familiar with.
However, here in hot and humid South Florida, thinner oils result in higher UOA wear metals, in my "fleet". Others have different results. I'm hard on things, it seems.
Turbo's rule.
#3404465 - 06/23/14 10:58 AM Re: is 0W-20 always better for mpg than 5W-20? [Re: Jasper8146]
jrustles Offline
So... is this a diesel engine we're all talkin about here?
"No matter how paranoid or conspiracy-minded you are, what the government is actually doing is worse than you imagine" W.Blum
#3423915 - 07/13/14 09:46 PM Re: is 0W-20 always better for mpg than 5W-20? [Re: Jasper8146]
Greasymechtech Offline
Loc: Paradise of Florida
Whether under warranty or not is irrelevant.
For the most MPG, use any full synthetic 0w20.
You probably wont see the mpg difference when compared to a full synth 5w20.
When the transmission is due for service, use a full synth fluid there too.
At what point should a lurker start posting :-)
Page 3 of 3 < 1 2 3
