For the duration of your test, your results were all compensated for in terms of air temperature, atmospheric pressure, variations in fuel density and energy content per pound, right? Chevron states that for each degree in API specific gravity the fuel has a 2% energy density variation. You did measure (and compensate for) the normal specific gravity variations in the fuel that was purchased, correct?
Of course the reason you had alternator failures was because it does take a lot of energy to decompose water, as it does for most oxides. Oxygen is a tenacious oxidizer. The problem is that it takes just as much energy (actually exactly as much) to break down that water as you get in combustion. So how it it possible to observe a corresponding increase in fuel economy with this system? Especially when you factor in the combustion inefficiency of even the most modern and efficient ICE. Nature will not be cheated.
Originally Posted By: Fleetmon
Back in the early '90's, we tried a few hydrogen generators on our 6V92 buses to increase fuel mileage. They did work and they did produce hydrogen but at a cost of many alternator failures. If I remember correctly, the company provided Delco 50DN alternators that had been modified to output more than 300 amps @ 24vdc and modified the alternator cooling system by increasing oil flow through the alt and using a fan built onto the pulley for airflow across the alternator.
It wasn't much of a fuel mileage increase and averaged around .2 MPG better...2.3 MPG to 2.5MPG on average but at 24M miles per year for the bus fleet, fuel savings would have been close to $1M dollars. It wouldn't cover the cost of very short alternator life (about 4,000 miles) let alone pay for the cost of the actual hydrogen generator and water tank plus installation.
