On cars that you want to keep a long time...
Here's Bar's Leak version of Water Pump Lube + Anti-Rust:
http://barsproducts.com/catalog/view/18-cooling-system-water-pump-lube-with-anti-rust-1311
Here's their summary: "Bar’s Leaks Cooling System Water Pump Lube with Anti-Rust protects aluminum, copper, iron and all other parts of the cooling system to help prevent the formation of rust and corrosion.
The water soluble oil formula lubricates the thermostat and the water pump seal. Compatible with ALL brands of antifreeze including conventional green or blue (Silicate-based) and extended life red/orange or yellow (OAT/HOAT) coolant. A must use if running only water in the cooling system, especially racing
applications.
OEM quality meets leading car and truck manufacturer requirements. For best results install once every 15,000 miles."
What say you? Does it help?
applications.
