My 2012 Cruze Eco
Originally Posted By: sasilverbullet
Rented a Cruz for a day and was impressed with the car.
Is there 2 or three different gas engines?
1.4l
eco 1.4l (turbo)
1.8l
How is the reliability of each of these? I want to buy it and drive it for 13~ years.
Thoughts? Ideas?
From a pretty darn satisfied owner of a 2012 Cruze Eco manual transmission with 88k miles on it:
2 gas engines: the 1.4 turbo and 1.8. The 1.4T is by far the superior engine. Lower NVH, better daily-driver power thanks to the turbo, and better fuel economy. It's port-injected and has a timing chain. At a 65 mph cruise, expect a automatic to get about 38-40 mpg, while my stick-shift Eco will get about 43-45 mpg. Then there's the diesel, which is basically a diesel Verano with a Cruze skin wrapped around it. Whole different car than the gas Cruzes.
Reliability: Mine's coming up on 3 years old, and has 88k miles on it. In that time it's needed two water pumps, both replaced under powertrain warranty. I also snapped some lug studs thanks to my over-torquing. That's been it for unexpected repairs. The water pumps are hit or miss. Either you get a good one, or it conks out quickly. It's an easy part-slinging job that's covered under powertrain warranty.
For being hard on oil, I started that meme! What I mean is that the oil really does need to be changed by 7500 mile at most, and to get that mileage a full synthetic oil is necessary. Otherwise, a semi-syn oil is good for about 5000 miles. GM reprogrammed the OLM for the 2014's to be much more conservative. If you buy new, follow the OLM. If purchasing used, change the oil at 7500 miles or 25% on the OLM, whichever comes first.
If traffic/family permit, get a stick-shift Cruze. That will get better fuel economy than a automatic. The only issue with the manual in the Cruze is that the OEM transmission fluid needs to be changed by 15k miles. Amsoil Synchromesh is a fantastic replacement, or Amsoil 75w-90 since you're in Texas and it's hot down there.
Aside from those issues, my Cruze has been a very good car. I've been quite happy with the NVH, space inside, fuel economy, ride, and handling. I still enjoy driving it after almost 3 years of ownership. For me it's a keeper.
