Just did a valve clearance inspection on a 2003 Toyota Sequoia with the 4.7L V8 (2UZ-FE) with 120k miles. The car was bought used with 30k miles dealer serviced in 2007 and switched over to synthetic 5w30, usually Castrol FST. The maintenance book calls for valve clearance inspection every 60k but this was the first as I have been hearing 1-3 ticking noises under acceleration (merging onto freeway). I thought it might be bad gas and ran 91 Shell but the 'ping' was still there. Also, when driving in the mountains, it sounds like a steam train in my opinion, but there's no power loss, and it climbs mountains at 70mph effortlessly in 3rd gear (out of 4).
Anyways, here are the valve covers and cam. I find it weird that the driver's side valve cover has some varnish while the passenger side is spotless. All valve clearances were in spec but the driver's side was at the limit of 0.35mm for exhaust and 0.25mm for intake valves. What say you?
Driver's Side Valve Cover
Passenger Side Valve Cover
Passenger Side Cam
Rear Half of Driver Side Cam
Front Half of Driver Side Cam
Passenger Side Cam
