i use Allis Charmers grease from the early 1970's that my dad used i have at least one more case and i never have front end problems due to wear on a grease related joint. We had cases of that stuff when i was a kid and i still have some left now.
I use the pink/red grease from NAPA. Its either NAPA or Valvoline. Ball joints take a chassis grease, its not a high speed application like a front wheel bearing.
Just as an FYI, front (or rear) wheel bearings are NOT considered high speed applications. High speed usually refers to >10,000 RPM. That is roughly 740 MPH for an averaged sized tire, more if you have a larger truck tire
I fill my gun with valvoline synpower. Nice and tacky, doesnt bleed out of my gun, some moly and seems to have markedly better specs than durablend for a few bucks more.
On a side note, has anybody used superlube nlgi2 for chassis grease?
