2014 5.0 mustang GT
Car had factory fill drained in early June and replaced with 5w20 Pennzoil Ultra. Factory fill was 7 month old motorcraft synth blend with 1800 miles on it.
Car will have about 5000 miles on it at most by the time it goes into reduced winter use sometime in November. So figure 3000 miles on the PU fill in there now. Winter use means driven once or twice per month over the winter for about 15-25 miles each time. Car is garaged and stays above freezing but there is no heater in there.
My question is do I need to drain the fill in there before I put it into reduced winter use/partial storage? Seems like a waste to drain that expensive oil out of there with so few miles on it and replace it with new stuff that will more or less just sit there for the most part over several months.
