Wix : 10k miles? (also comparison question)
by Kuato
05/26/16 07:14 PM
Witnessed accident and driver running from scene
by stranger706
05/26/16 07:06 PM
Initial Vehicle UOAs
by GumbyJarvis
05/26/16 06:20 PM
04 C1500 1/2 Ton; P/S Fluid Disappearing
by TexasTea
05/26/16 05:52 PM
TV logos
by chiefsfan1
05/26/16 05:51 PM
Day 2 the "right" trans-filter doesn't fit either
by 69GTX
05/26/16 05:37 PM
Fram pro synthetic longevity question
by BeerCan
05/26/16 05:25 PM
Motorcycle Scan Tools
by George7941
05/26/16 05:17 PM
RL D6 vs T-WS
by MaximaGuy
05/26/16 04:54 PM
Trailer tire air pressure question
by silveravant
05/26/16 04:09 PM
Liqui Moly or Valvoline Synthec ?
by Mickxalix
05/26/16 03:56 PM
2002 Camry 2.4 147.5k with 7500mile oci GC 0w30 wi
by Thebuckaman
05/26/16 02:53 PM
watergate528, iamtheanimal, 1991300sl, Rdyno, Darsahn
57993 Registered Users
101 registered (2015_PSD, abycat, 4WD, Abakev, 69GTX, 1971tr350, 10 invisible), 1607 Guests and 134 Spiders online.
57993 Members
66 Forums
249448 Topics
Page 2 of 4 < 1 2 3 4 >
#3402461 - 06/20/14 07:00 PM Re: Lucas SYNTHETIC oil stabilizer [Re: 901Memphis]
Stelth Offline
Loc: California
The regular Lucas Oil Stabilizer is based on heavy bright stocks, with 20-30% Olefin Copolymer viscosity improvers. This much can be surmised from the MSDS.
The Synthetic Oil Stabilizer is much less viscous, with a viscosity of 45 at 100C. It seems to be based on a heavy Group III oil, but the MSDS doesn't say what else is in it. Probably more viscosity improver, although a tech support guy at Lucas said there's some group IV in it.
Rand, can you tell us what's "terrible" about Lucas Gear Oil?
Experts are often wrong, but rarely in doubt.
#3402466 - 06/20/14 07:07 PM Re: Lucas SYNTHETIC oil stabilizer [Re: HAWG4LIFE]
CHARLIEBRONSON21 Online   content
Loc: MEMPHIS, TN
All I've found it good for was building the old mustang motor and using as assembly lube.
'13 Fusion Hybrid: 5w20 PUP/FU
'15 Civic Si: 0W20 PPPP/FU
'16 Fusion Hybrid: FF
'14 Odyssey: 0w20 PUP/FU
'93 Civic: 5W30 M1/TG
'99 SVT Cobra: 5W30 M1/FU
#3402493 - 06/20/14 07:44 PM Re: Lucas SYNTHETIC oil stabilizer [Re: 901Memphis]
SuzukiGoat Offline
Loc: Louisiana
Originally Posted By: 901Memphis
I can't imagine what happens when someone does a double dose or more on a higher specified grade. Like the guy at Autozone I saw grabbing two bottles of Lucas to go with his 10w40 high mileage into a 5w20 Toyota engine.
While I hate lucas...prove to me it would matter...at all.
Ive run a 5w20 toyota motor on 20w50 with motor honey...with zero ill effects. The vvti didnt even realize it.
1995 Suzuki Sidekick Auto 4x4 on 33s. Low mileage motor in 200k body. Denso with M1 0w40.
1996 Geo Tracker Auto 4x4 Denso VNG 10w30. 120k.
#3402610 - 06/20/14 10:24 PM Re: Lucas SYNTHETIC oil stabilizer [Re: SuzukiGoat]
901Memphis Offline
Loc: Northern Kentucky
I COULD prove it to you.... but then i'd have to kill ya.
2002 Buick Century 125k - Built 4T65e(Maxlife) - M1 0w40 /Fram Ultra XG 3387A
1998 Nissan Altima 335k - 5MT - M1 HM 5w30/Fram Ultra XG7317+MOS+ATP 205
#3402965 - 06/21/14 11:33 AM Re: Lucas SYNTHETIC oil stabilizer [Re: HAWG4LIFE]
tom slick Offline
Loc: Central Coast, Calif.
Aren't you guys scared of running unstable oil? The other big oil companies haven't discovered the secret sauce for stable oil. Luckily a select few enlightened additive companies share their complex chemistry and vast technological breakthroughs with us consumers.
You get what you pay for...
So keep in mind how much you paid for this advice.
#3408428 - 06/27/14 12:16 PM Re: Lucas SYNTHETIC oil stabilizer [Re: HAWG4LIFE]
postjeeprcr Offline
Loc: USA
I had a VOA done years ago of the Lucas Synthetic Oil Stabilizer, I will look for it and post the results once I find it.
If I agreed with you, we'd both be wrong.
#3410107 - 06/29/14 03:42 PM Re: Lucas SYNTHETIC oil stabilizer [Re: postjeeprcr]
mr_blackstock Offline
Loc: Victoria, Australia
G'day,
Although I have only used Lucas oil stabiliser a few times, I have had nil issues. Predominantly I use Morey's oil stabiliser, and have been for a few years now in my bikes. Initially when I put Morey's in my bike the vibration was reduced massively, so much so that the bike happily would rev out higher than before without the associated excessive vibration. I thought I might have been imagining the change, so I got rid of it, and put in my usual oil without additives. After an hours ride I got home and added the additive again and I have not once doubted it's effectiveness.
A type of proof I do remember is an oil change I did on the bike a year ago. Usually I empty my oil drain tray soon after it is out of the bike, in this instance I was lazy and left it over night. In the morning I emptied it into my old oil drum and noticed a thick oily coating where the oil had sat. It was oil alright, but sticky. I had to use degreaser just to get the stuff off! Normally when I empty old oil into my drum nothing gets left in the tray, I can usually wipe it with a rag and it's clean. This morey's stuck to the tray after 5000kms. Good enough for me..
#3413112 - 07/03/14 01:53 AM Re: Lucas SYNTHETIC oil stabilizer [Re: HAWG4LIFE]
Marco620 Offline
Loc: Midwest, Rural KS
I would say its better to run liquimoly motor oil saver than lucas. Even if you ran it and LM mos2 you would have 1/3 qt left to add actual oil and it would be better than lucas. When I thought I needed an oil supplement long ago, I used a qt of redline sae 30wt and it filled my void. Lucas is awesome on door hinges and sewing machines; that is it along with lower oci.
#3413651 - 07/03/14 04:37 PM Re: Lucas SYNTHETIC oil stabilizer [Re: HAWG4LIFE]
Clevy Offline
Loc: Saskatoon canada
Originally Posted By: HAWG4LIFE
I know the regular oil stabilizer is junk, but is this any better?
No.
What part of an oil formulated today is unstable and requires something so thick,and non-additized to compensate.
Try running non-additized oil is an engine and time its life with a stopwatch.
2006 Charger RT
Miles x 2 per oil filter
#3413955 - 07/03/14 09:44 PM Re: Lucas SYNTHETIC oil stabilizer [Re: Clevy]
GatorJ Offline
Loc: Tampa
No.
LOL. Or requires Liqui-Moly? Quick answer? None.
#3413966 - 07/03/14 09:53 PM Re: Lucas SYNTHETIC oil stabilizer [Re: GatorJ]
Clevy Offline
No.
Really.
I've cured gasket leaks with liqui-moly motor oil saver and gained mileage using mos2.
So do tell genius,considering they are additized,and actually do something how exactly do they compare to a non-additized,molasses thick additive.
If you can show me the exact same benefits just using a standard motor as I've experienced using liqui-moly then by golly I'll quit buying the stuff,til then how about sticking to the topic.
2006 Charger RT
#3430557 - 07/20/14 07:48 PM Re: Lucas SYNTHETIC oil stabilizer [Re: HAWG4LIFE]
Clubber_Lang Offline
Loc: SC
First of all, i would never use lucas.
However i do know someone who used it every oil change in his 3.0 ranger.
It went 750,000 miles before it burnt a valve. I attribute this to that tough 3.0 motor, hwy driving and regular oci. Not the lucas. I think it was in spite of the lucas.
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery." Sir W.C.
#4026490 - 03/01/16 05:34 PM Re: Lucas SYNTHETIC oil stabilizer [Re: HAWG4LIFE]
Ram01 Offline
Loc: New York Queens
Lucas is a quality oil stabilizer use it to extend your engine life and OCI
#4026533 - 03/01/16 06:13 PM Re: Lucas SYNTHETIC oil stabilizer [Re: Ram01]
Garak Offline
Loc: Regina, Saskatchewan, Canada
How does LOS extend either?
Plain, simple Garak.
2008 Infiniti G37 coupe - Mobil Delvac 1 ESP 5w-40, Wix 51358
1984 F-150 4.9L six - Quaker State GB 10w-30, Wix 51515
#4026588 - 03/01/16 07:24 PM Re: Lucas SYNTHETIC oil stabilizer [Re: Garak]
turtlevette Offline
Loc: Massachusetts
You're in the group that keeps pounding the table for more viscous oil fill.
It makes whatever you run more viscous.
USA-1
