Originally Posted By: spasm3
Originally Posted By: Chris142
Originally Posted By: simple_gifts
I'm boycotting that FOD walk.
can you splain what you said to us not in the know?
I think it means foreign object damage walk. Doesn't the navy walk the catapult lanes to look for damage, foreign objects?
It's Foreign Object Debris. Bits of rock/metal/rubber/whatever on ramps/runways/and taxiways that can do a lot of damage to an aircraft. After all, FOD is what took down that Air France Concorde.
A FOD walk is done periodically at airports to check for anything that may cause damage. If you find it, you pick it up; in this case, the FOD is a ton of bricks.
Pavers for a ramp material isn't totally uncommon, but doing a full power run-up on one isn't a great plan.
