Do I need a better tire for PNW trip?
by The_Eric
05/29/16 11:51 PM
Turtle Beach PC headset hack
by asand1
05/29/16 11:34 PM
Lengthy question for the seasoned oil gurus
by Jetstreamz06
05/29/16 11:10 PM
Jeep Cherokee Heater Valve - Brands?
by Nick1994
05/29/16 11:00 PM
Hyundai Entourage/Kia Sedona minivans
by Number_35
05/29/16 10:41 PM
Oil in air breather tubing
by Nissan101
05/29/16 10:06 PM
Dust caps needed to protect wheel bearings?
by Drew99GT
05/29/16 09:51 PM
2014 Mazda CX5 SkyActiv
by Matt_V
05/29/16 09:38 PM
getting rid of pwc with intermittent problem?
by motor_oil_madman
05/29/16 08:36 PM
Difference between silicone caulking ?
by Merkava_4
05/29/16 06:15 PM
The Top Dexos2 Oil Available in the USA is What?
by Best F100
05/29/16 05:24 PM
Virgin Puro L14006 [Cut open]
by Run
05/29/16 05:13 PM
Moutainman31282, AlaninPA, z0bug33, smitty31, jimshep
58013 Registered Users
56 registered (4WD, 2010Civic, 79Eldor, AirgunSavant, 3800Series, 6 invisible), 991 Guests and 321 Spiders online.
58013 Members
66 Forums
249581 Topics
Page 1 of 3 1 2 3 >
#3400147 - 06/17/14 09:37 PM plastic fuel filter used as coolant filter
901Memphis Offline
Loc: Northern Kentucky
This is the second time I've done this. First one was a metal Fram G15 ran about 100 miles, this is the duralast g15 cross reference to that spliced into my Ford Taurus overflow return line. Less than 100 miles over two weeks of short trips ruined the plastic filter. It was fine until I did some full throttle runs to see if it would implode, it did get very wavy at full load and shortly after the next day the element came loose.
In this short time it loaded the filter good. I might do it again for the quick cleanup.
First picture is the day of the install, rest are of the removal after failure.
No leaks or anything but the filter element came loose and stopped filtering. Maybe it reached its holding capacity but I want to try it again without abusing the throttle and see how long it lasts. Also there's less contamination now that I've run two filters through it.
Going to try the Wix cross reference soon as it looks more robust.
This cooling system seems to be rough on everything. Even after doing a thorough flush two years ago and replacing the dirty overflow tank and cap with a genuine Motorcraft the system is getting dirty again. I thought it was the older style green coolant causing it so it's had Prestone all makes all models in there but it still gets sediment in the tank and floating particles on the surface of the fluid.
Currently the heater core is plugged and I'm not putting much money into this beater.
2002 Buick Century 125k - Built 4T65e(Maxlife) - M1 0w40 /Fram Ultra XG 3387A
1998 Nissan Altima 335k - 5MT - M1 HM 5w30/Fram Ultra XG7317+MOS+ATP 205
#3400162 - 06/17/14 09:56 PM Re: plastic fuel filter used as coolant filter [Re: 901Memphis]
MinamiKotaro Offline
Loc: TN
I used a metal one on the old brown van. It caught a LOT of crud, so much so that the element was completely squashed. I don't think it could even flow anymore. It never came apart, though.
1967 VW Beetle: Mag1 5w40 All Fleet/Motorcraft FL400S
2004 Saturn Ion: Delo 5w40/Wix 57082XP
2014 Polaris Ranger 570: Delo 5-40/Wix 51356
#3400168 - 06/17/14 10:00 PM Re: plastic fuel filter used as coolant filter [Re: 901Memphis]
michaelluscher Offline
Loc: Tri States Little Italy
Flush the heater with CLR so you have heat.
There's probably a stronger spec clear fuel filter you can keep using to clean it out.
'06 Toyota Camry SE V6 3MZ-FE 51k
'01 Mercury Villager Estate VG33E 48k
'06 Ford Taurus SE Vulcan 48k
'13 Chrysler 300 3.6 Pentastar 45k
2012-2015
#3400169 - 06/17/14 10:02 PM Re: plastic fuel filter used as coolant filter [Re: 901Memphis]
demarpaint Offline
Loc: NY
I wish I had a pressurized recovery tank in any of the vehicles I own. If I did I'd do exactly what you did. Nice, cheap, easy, and it works. Cutting a heater hose and plumping in a filter to a 5/8" or 3/4" heater hose is a bit more challenging, and costly.
Thanks for posting!
God Bless Our Troops
#3400180 - 06/17/14 10:15 PM Re: plastic fuel filter used as coolant filter [Re: 901Memphis]
Chris142 Offline
Loc: apple valley, ca
Thats pretty neat but I'd use a metal one for a high pressure fuel injected system. The carbed ones you used are designed for about 5 psi but fuel injection systems can do around 60 psi on some cars.
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#3400192 - 06/17/14 10:35 PM Re: plastic fuel filter used as coolant filter [Re: Chris142]
artificialist Offline
Loc: Florida
If he is running a stock radiator cap, his cooling system probably uses 15 PSI of pressure. That could be a problem.
I never imagined this would work. Often plastic products are designed for a certain grop of chemicals. One for gasoline, one for oil and ATF, one for antifreeze, one for brake fluid, and one for diesel fuel.
2010 Lancer Ralliart Sportback
#3400216 - 06/17/14 11:27 PM Re: plastic fuel filter used as coolant filter [Re: artificialist]
901Memphis Offline
Which is why i only had it on there for about 100 miles. The plastic didn't seem to have much of a problem short term the failure was the adhesive holding the element to the base inside.
#3400226 - 06/17/14 11:38 PM Re: plastic fuel filter used as coolant filter [Re: 901Memphis]
71Chevyguy Offline
Loc: Martinsburg West Virginia
That is a good idea! Would be nice to get a re-usable filter of some sort that is tougher and easy to clean for re-use. Great to use once in a while to keep things clean and crud free.
15 Chevy Sonic RS QSUD / Delco filter
85 Buick Skylark 2.5 VNGHM / PF52
87 Caprice 305
71 Nova 250
#3400268 - 06/18/14 01:23 AM Re: plastic fuel filter used as coolant filter [Re: 901Memphis]
901Memphis Offline
http://www.magnafuel.com/products/accessories/filters/
That looks interesting but probably too much for me.
#3400599 - 06/18/14 12:55 PM Re: plastic fuel filter used as coolant filter [Re: 901Memphis]
901Memphis Offline
Also I saw one plastic filter similar said rated for 10 psi, so it was only stressing it a little.
#3400634 - 06/18/14 01:39 PM Re: plastic fuel filter used as coolant filter [Re: 901Memphis]
901Memphis Offline
Stay tuned i am going to grab a Wix 33003 and put it on tomorrow and hopefully i can put enough miles on it to see what it catches!
http://www.oreillyauto.com/site/c/detail...5&ppt=C0024
#3400664 - 06/18/14 02:25 PM Re: plastic fuel filter used as coolant filter [Re: 901Memphis]
morepwr Offline
Loc: ventura, ca
Interesting!
#3400936 - 06/18/14 08:32 PM Re: plastic fuel filter used as coolant filter [Re: 901Memphis]
901Memphis Offline
Went to pick up this Wix 33003 on break at the close by O'Reilly and wanted to put it on before my short drive home tonight but I think I left my little piece of rubber hose with clamp in the other car, so it will have to wait. Hopefully I can locate the little hose since it won't work without it.
Initially impression of the Wix compared to the Duralast cross reference leave me feeling the Wix is more robust and should hold up better.
The duralast was made in China but had a metal end cap, the Wix is made in Russia and has only potting material holding the end together. Time will tell if it lasts more than 100 miles without the glue coming off.
#3401016 - 06/18/14 09:46 PM Re: plastic fuel filter used as coolant filter [Re: 901Memphis]
doitmyself Offline
Loc: MI
This is an excellent concept for the Vulcan, which has a history of coolant rust particle production that clogs the heater element that has very small passages.
If you ever back flush the heater core via the heater hoses (lots of you-tube videos), you will literally get a cup or more of sediment out.
You need a much bigger filter.
"There are things you do that put food on the table, and there are things you do that feed your soul." I am blessed to have them be the same things.
#3401123 - 06/19/14 12:15 AM Re: plastic fuel filter used as coolant filter [Re: doitmyself]
901Memphis Offline
Yes i flushed it very thoroughly 2 years ago including attaching a garden hose directly to the heater core outlet and inlet and there was a huge amount of rust sediment that came out. It was almost endless, the heat only partially came back then went mostly out again a few months later.
Page 1 of 3 1 2 3 >
