Stapled down carpets ???
by Oldtom
07/29/16 01:51 AM
MicroGard (Wix) 57047 ~7k miles
by MrQuackers
07/29/16 01:24 AM
Ford 4.6 with Supercharger, 2,000 mi. / yr.
by milkboy
07/29/16 12:50 AM
Only secure content is displayed?
by Eddie
07/28/16 11:35 PM
2008 Honda Element oil question
by fujirio
07/28/16 09:50 PM
TIRE QUESTION
by renegade_987
07/28/16 09:46 PM
What's your favorite outboard and why ??
by BrocLuno
07/28/16 09:30 PM
Briggs 'Quantum 6.0' Flathead top no load 2600RPM
by Colt45ws
07/28/16 09:15 PM
EPA efficiency testing may not work, at all
by wemay
07/28/16 09:11 PM
Mobil 1 0w40 for 2013 4.8 V8
by CapitalTruck
07/28/16 09:04 PM
2013 Passat service
by powersmo
07/28/16 08:24 PM
A/C troubleshoot
by Leo99
07/28/16 07:50 PM
_hashtagusername, larrybroad123, dr_p, CapHead, rowebil
58632 Registered Users
24 registered (chance, earlyre, Drosselmier, CATERHAM, Ducked, 3 invisible), 909 Guests and 9 Spiders online.
58632 Members
66 Forums
252385 Topics
Page 2 of 3 < 1 2 3 >
#3399756 - 06/17/14 12:30 PM Re: Memory or motherboard? [Re: daves87rs]
Nick R Offline
Loc: Albany, NY
Originally Posted By: daves87rs
Originally Posted By: Nick R
It's a bad motherboard. My grandmothers year old gateway did this literally last week. Was fine before, then 3 beeps, no post, no boot (fans run). I tried a different PSU, different RAM, no change. She bought the service plan on it through Best Buy, so I took it over there and the geek squad guy noticed that some of the caps on the motherboard were in fact bulging. I hadn't even looked for that, as it's barely a year and a half old and I'd never seen caps that new do that before. It was sent out for repair, and sure enough. They replaced the motherboard, and it works perfectly again.
No fan running here....runs like it normally would. But at the moment I'm between the ram or motherboard....
Fans should normally run when you turn the computer on so I'm not sure what you mean. Besides bad ram usually causes crashes and BSODs, not no post conditions
2013 Ford Focus SE 2.0L/73,000miles/Motorcraft Blend 5W-20/FL-400S
#3400119 - 06/17/14 08:57 PM Re: Memory or motherboard? [Re: Doog]
Subdued Offline
Loc: Youngstown, NY
Kinda wondering if it might be the memory since my wife has a habit once in a while to just pull the cord if it does not turn off...
My guess...the HD has been crashed one too many times.
Pulling the cord is no different than shutting the computer down to the HDD. No different at all. Drives don't need to be "parked" like they had to 30 years ago anymore. The only problem that can occur from this is file corruption if the plug is pulled in the middle of a write, but certainly not a no boot condition.
This actually sounds much more like a swollen caps problem than anything else.
2008 Chrysler Town & Country Touring 119k
2007 Toyota Yaris S 135k
2001 Toyota Corolla LE 159k
2001 Toyota Corolla CE 128k
#3400136 - 06/17/14 09:26 PM Re: Memory or motherboard? [Re: daves87rs]
dave munson Offline
Loc: Illinois
You can try to pull the memory and put it back. Vacuum out the motherboard. Also re-seat the video card and any other cards in slots. After that, I would not recommend spending anything on a six year old gateway.
dem
#3400446 - 06/18/14 09:48 AM Re: Memory or motherboard? [Re: daves87rs]
BlitzPuppet Offline
Loc: Houston, Texas
CMOS battery wouldn't cause the three short beeps, that's indicative of a memory failure on some motherboards...can't be for certain though unless I knew what BIOS your pc was running.
Try swapping DIMMs/Banks and see if it changes.
The worst that could really happen with a CMOS battery being dead is usually system time/settings not being correctly saved.
Edited by BlitzPuppet (06/18/14 09:48 AM)
#3400621 - 06/18/14 01:17 PM Re: Memory or motherboard? [Re: daves87rs]
Rand Offline
Loc: NE,Ohio
usually with memory failure both chips wont fail at same time.
try booting with 1 chip then the other in the appropriate slot.
(some boards wont boot with 1 chip in the wrong slot)
my $$$ as most others have said is on the MB, so much stuff can go bad on an aging MB compared to cpu or memory.
Edited by Rand (06/18/14 01:17 PM)
2015 Forester I-Premium 6MT
#3400849 - 06/18/14 07:00 PM Re: Memory or motherboard? [Re: daves87rs]
javacontour Offline
Loc: Illinois
If you haven't sorted it out yet strip the computer down to the minimum configuration. No PCI cards other than video if there is no on-board graphics, on DIMM, perhaps no hard drives either, just to see if you can reach BIOS.
If you can, either one of the removed components is suspect, or the power supply cannot support all the hardware.
network down, IP packets delivered via UPS -BOFH
#3400910 - 06/18/14 07:59 PM Re: Memory or motherboard? [Re: daves87rs]
daves87rs Offline
Loc: Michigan
Didn't have much time on it today, but I did clean it and took a good look inside. Caps on the MB look fine. Plan to play with moving the ram tomorrow.
It was also mentioned to be that it could be an OS issue as well. This happened shortly after a windows update (for vista) Same update done on my labtop I am on how had some odd issues a well. Even blue screened once. I set it back before that update, and it has no issues at all.
Could these updates have screwed this all up to mess up the boot up? Not sure if would still cause those beeps, but I figured I would ask.....
Whatever you are, be a good one.
#3400924 - 06/18/14 08:15 PM Re: Memory or motherboard? [Re: daves87rs]
ClutchDisc Offline
Loc: Detroit area
I don't see an OS issue causing the beeps and preventing you to get to the BIOS. I would say your best bet is to try pulling one of the RAM sticks like rand said and booing with just the one. Then switch the sicks and try booting with just the other.
2001 Chevy S-10 2.2L 5-speed manual - Valvoline Maxlife Full-syn 5w30
The box said: "Requires Windows XP or better."
So I installed Linux.
#3401012 - 06/18/14 09:44 PM Re: Memory or motherboard? [Re: daves87rs]
The_Eric Offline
Loc: Iowa
It wouldn't hurt to look at all the caps again. The Gateway that I was referring to earlier had one bulged cap- and it was very slightly bulged. In fact I missed it the first time around and a friend was actually the one that found it.
2005 Lincoln Aviator 4.6 DOHC
2000 Honda Accord 2.3
2001 Hyundai Elantra 2.0
1979 Ford F-150 351M
#3401285 - 06/19/14 08:34 AM Re: Memory or motherboard? [Re: daves87rs]
BlitzPuppet Offline
Loc: Houston, Texas
The only "Updates" that could screw this up would be a BIOS update...and windows doesn't provide those.
You're definitely looking at something hardware related here, and RAM is the most likely culprit.
Edited by BlitzPuppet (06/19/14 08:34 AM)
#3401570 - 06/19/14 02:40 PM Re: Memory or motherboard? [Re: daves87rs]
badtlc Offline
Loc: KC
I had a PC recently brought to me that was unable to boot after Windows 7 updates. Not sure what happened, but the updates made the partition unreadable. I couldn't restore anything. I'm guessing it was a bios conflict with the new windows update. Reformatted, installed all udpates, everything works fine.
I had never seen windows updates do such a thing before. I thought for sure it was a dead hard drive when I first got it.
2007 Ford Escape XLS 2.3L ATX, Trop Artic 5W30, Fram OCOD, 140k+
2015 Chrysler T&C, 45k+
#3401586 - 06/19/14 02:59 PM Re: Memory or motherboard? [Re: daves87rs]
JustinH Offline
Loc: Texas
6 years is good service for a computer, take the hard drive out, put it in safe keeping, then recycle the computer.
Go buy another one.
Why the headache?
'10 Toyota Rav4 Sport
'08 Toyota Matrix
#3401597 - 06/19/14 03:10 PM Re: Memory or motherboard? [Re: JustinH]
ClutchDisc Offline
Loc: Detroit area
Go buy another one.
Why the headache?
Let's see, I have a 10 year old desktop that performs better than day one, a netbook that is about 9 years old, my dad has a desktop that is 8 years old and also performs better than day one...
Seriously???
#3401616 - 06/19/14 03:47 PM Re: Memory or motherboard? [Re: daves87rs]
JustinH Offline
Loc: Texas
I see little need in working on an old computer. They are disposable appliances.
'08 Toyota Matrix
#3401621 - 06/19/14 03:53 PM Re: Memory or motherboard? [Re: JustinH]
ClutchDisc Offline
Loc: Detroit area
If that is what you want, but I will keep the $600+ I saved by not replacing mine!
