Fishing reel drag grease
by bernau
07/29/16 04:26 PM
Sulfated Ash, wt%, ASTM D 874 test questions
by mbacfp
07/29/16 04:02 PM
HD radio
by 007
07/29/16 03:51 PM
Front end repair
by possum328
07/29/16 03:49 PM
Purolator 10111 Red Can
by FordBroncoVWJeta
07/29/16 03:30 PM
Carquest #R85372, 2013 E-250 van, 4,500k
by car51
07/29/16 03:03 PM
Strange failure: Starter AND flywheel cogs ripped
by lars11
07/29/16 02:22 PM
My email from Castrol about Magnatec
by Tech819
07/29/16 02:13 PM
Audi 5000 / Known Stop-Leak Compatible w/ CHF 7.1?
by Miles07PT
07/29/16 01:41 PM
Observations on Workplace corrosion
by Vdubuk
07/29/16 12:15 PM
Oil filter change NIGHTMARE
by MetalSlug
07/29/16 12:08 PM
First time flushing an 05 Tacoma
by Back40
07/29/16 11:53 AM
_hashtagusername, larrybroad123, dr_p, CapHead, rowebil
58632 Registered Users
82 registered (2oldtommy, 440Magnum, Al, 97f150, 901Memphis, 8 invisible), 2095 Guests and 12 Spiders online.
58632 Members
66 Forums
252411 Topics
#3389853 - 06/05/14 02:57 PM Larger tire size
outoforder Offline
Loc: Ohio
Only tire size available for my 08 Focus is a 50R. The tire I want only goes as low as 55R. What would happen if I put on these tires instead of OEM?
2003 Grey Jetta TDI 309,000 miles
1999 Green Jetta TDI 353,000 miles
2002 White Expedition 170,000 miles
2003 Black Solara Convertible 194,000 miles
#3389854 - 06/05/14 02:59 PM Re: Larger tire size [Re: outoforder]
Quattro Pete Offline
Loc: Great Lakes
What is 50R?
Can you provide complete nomenclature/tire size?
'02 530i (Edge HM 10W-40)
'15 Q5 3.0T (Edge 5W-40)
#3389869 - 06/05/14 03:22 PM Re: Larger tire size [Re: outoforder]
Loc: Great Lakes
If it's 205/50/16, then you could potentially run 195/55/16 instead. Load index is the same, and the overall diameter would be less than 2% different from stock.
#3389873 - 06/05/14 03:25 PM Re: Larger tire size [Re: outoforder]
copcarguy Offline
Loc: PA
As stated above, you'll need the entire tire size... There is a great tire size calculator here:
http://www.miata.net/garage/tirecalc.html
You can compare your current size to another, and it'll tell you how much it'll throw off your speedometer, revolutions per mile, etc...
HTH
#3389992 - 06/05/14 05:19 PM Re: Larger tire size [Re: outoforder]
outoforder Offline
Loc: Ohio
OEM tire is 205/50R-16. The tire I want doesn't come that small. Nearest size is 205/55R-16.
#3389999 - 06/05/14 05:33 PM Re: Larger tire size [Re: outoforder]
HTSS_TR Offline
Loc: Lake Forest, CA
OEM size diameter is 24.1", 205/55-16 is 24.9" about 3.4% larger than OEM.
Is it okay with your car, hard to tell.
I tried 245/45-17 instead of OEM 235/45-17 on my E430 10-11 years ago, the ABS malfunction within 100 miles such that I had to go back to OEM size, and the ABS malfunction light went off within a mile of driving.
'00 MB E430
'04 Honda S2000
'06 Volvo V70
'14 Honda Accord LX
"Throwing food away is like stealing it from the poor and hungry" Pope Francis
#3390003 - 06/05/14 05:36 PM Re: Larger tire size [Re: outoforder]
outoforder Offline
Loc: Ohio
Car is a 2008 Ford Focus. Apologies for not including all information in earlier posts. The tire guy at Sears appears knowledgeable and has no qualms about this. However, it is Sears…… :-/
Tires are currently being installed. We will know soon. I have 30 days to like them so if anything goes wrong, I can take them back.
#3390406 - 06/06/14 07:03 AM Re: Larger tire size [Re: outoforder]
CapriRacer Offline
Loc: Somewhere in the US
According to Discount tire, a 215/50R16 will fit, but they don't list the 205/55R16. That's probably because it's over 3% different in diameter. They don't like recommending anything more than that.
CapriRacer
Visit my web site: www.BarrysTireTech.com
#3390428 - 06/06/14 07:37 AM Re: Larger tire size [Re: outoforder]
outoforder Offline
Loc: Ohio
I got 205/55R-16 Hankook Road Handlers on the car. Drove 20 miles home with no issue. The vibration from previous tires is gone. I realize this is a statistically insignificant distance, but so far, so good.
#3400292 - 06/18/14 03:04 AM Re: Larger tire size [Re: outoforder]
Darris Offline
Loc: Toronto, ON. Canada
Your spedometer and odometer will be slightly off due to the computer pre-supposing a few more wheel revs per mile. Might slightly effect metrics such as instant & average fuel economy.
I recently took possession of a vehicle with larger than stock diameter. It slows it down a little off the line, and accelerating within city speeds, but takes less gas to maintain highway speed. Car seems to have more momentum and takes a little more brake to bring it to a stop. I imagine it will wear the brake pads a bit sooner than stock diameter or smaller.
Edited by Darris (06/18/14 03:04 AM)
'02 Nissan Altima 2.5L 2011-2014
'03 Nissan Altima 2.5L 2014-
#3400574 - 06/18/14 12:23 PM Re: Larger tire size [Re: outoforder]
Ken2 Offline
Loc: Washington St.
205 mm across the width of the tire body (approximate)
50% aspect ratio = width to height ratio, so the tire from bead to tread is about 52.5 mm high
R = radial
16 = wheel rim diameter in inches
Every gun that is made, every warship launched..a theft from those who hunger and are not fed, those who are cold and not clothed.
Gen. Eisenhower
