Sealant for threaded air hose fittings.
by BigD1
02/12/16 10:37 PM
on line data search programs - which is best?
by bmwjohn
02/12/16 10:11 PM
What size air compressor is needed
by ram_man
02/12/16 09:45 PM
DHS wants to force car owners to use OEM parts
by faltic
02/12/16 08:54 PM
Castrol Edge 5w30 no longer A5/B5
by slacktide_bitog
02/12/16 08:20 PM
Best Oil Analysis?
by countryboy9799
02/12/16 07:28 PM
Left my lights on and battery died.
by joegreen
02/12/16 07:25 PM
Honda CRX '91 transmission fluid
by jhmed80
02/12/16 07:18 PM
It's winter, let's take out the... Motorcycle???
by OVERKILL
02/12/16 06:54 PM
Home Testing for Gas in Oil?
by landtoy80
02/12/16 06:54 PM
Cost to replace windshield.
by Oldmoparguy1
02/12/16 06:44 PM
Oil Life Monitor vs. Mileage vs. Time
by HOG
02/12/16 06:24 PM
RTS, jhmed80, engus, Rob_Pol, Nick24w
56901 Registered Users
79 registered (74DartSport, akela, 2015_PSD, 90crvtec, 04SE, 01_celica_gt, 3 invisible), 1144 Guests and 204 Spiders online.
56901 Members
66 Forums
244623 Topics
#3218199 - 12/16/13 08:35 AM Best Grease for High Speed- High Load Bearings?
fins Offline
Loc: ohio
Have been reading the oil forums for years.......but just started reading all about grease. All kinds of grease red, moly, marine, synthetic, hi temp, etc......
I have a 72" finish mower behind my tractor......the bearings on the blades operate at pretty high speed and under some load.
What would be the best grease for this type of operation?
Would the same grease be recommended for wheel bearings?
#3218267 - 12/16/13 09:28 AM Re: Best Grease for High Speed- High Load Bearings? [Re: fins]
johnnydc Offline
Loc: Rochester, New York
I would have to believe wheel bearing grease would work good for that application.
1996 Mercury Cougar XR7 V8
2009 Mercury Milan V6
VWB and Motorcraft Filters
#3218407 - 12/16/13 11:50 AM Re: Best Grease for High Speed- High Load Bearings? [Re: fins]
229 Offline
Loc: Mid Atlantic
Chevron delo EP grease and Castrol Pyroplex are two that are well regarded.
Eneos Dealer
#3218418 - 12/16/13 12:03 PM Re: Best Grease for High Speed- High Load Bearings? [Re: fins]
Dufus2 Offline
Loc: Virginia
Tacky Red grease with a 70 lb Timkin rating would do better than just plain chassis grease. Usually the industrial grease does well due to the hammering load of the gearbox pushing against the blades. Chevron, shell, schaffers they all have a good product that is not real expensive.
I used shell alvania and a few others with good results. Now days, I use Amsoil grease and their GLC is excellent, or the Truck grease.
ASE Certified in Med/Heavy Truck Service including A9
Heavy Equipment Repair, Fleet Maintenance
Real Cars Rattle and Smoke a Little
#3218764 - 12/16/13 05:06 PM Re: Best Grease for High Speed- High Load Bearings? [Re: fins]
Ramblejam Offline
Loc: Kentucky
Here's what I use: http://docs.mystiklubes.com/msds_pi/M20026.pdf
Excellent performance & available at your local Wal-Mart for $3.67.
Pick up a battery powered gun and grease often!
#3219022 - 12/16/13 09:11 PM Re: Best Grease for High Speed- High Load Bearings? [Re: fins]
tom slick Online   sleepy
Loc: Central Coast, Calif.
The good news is you don't technically have high speed bearings. High speed bearings are about 10k rpm and above. A good grease rated for wheel bearings should serve you well.
You get what you pay for...
So keep in mind how much you paid for this advice.
#3392113 - 06/08/14 11:04 AM Re: Best Grease for High Speed- High Load Bearings? [Re: fins]
Raybo Offline
Loc: Clearwater ,Florida
#3400346 - 06/18/14 07:13 AM Re: Best Grease for High Speed- High Load Bearings? [Re: fins]
Kestas Offline
Loc: The Motor City
I agree with Tom. Lawn mower bearings are not considered high speed bearings.
#3408390 - 06/27/14 11:04 AM Re: Best Grease for High Speed- High Load Bearings? [Re: fins]
ironman_gq Offline
Loc: MN
I've always used disc brake wheel bearing grease. Mystik is what most of my stuff gets, it's cheap and not a bad grease.
#3452529 - 08/11/14 03:54 PM Re: Best Grease for High Speed- High Load Bearings? [Re: fins]
kawzak Offline
Loc: South Tx usa
At my work we designed a piece of equipment that had alot of heat and had a thrust brg that was subjected to both. At first I was going to use Dupont Krytox-extreemly expensive (typically I think it is in alternator brgs). However ater much research we decided on Redline brand CV-2. It handles both issues very well. it does turn brown-but I was told it would. We have been running this grease for over 2 yrs now. It works for us.
