Originally Posted By: CapriRacer
Oh, and 01rangerxl,
It's clear you have an alignment problem. That's the first thing about the photo that jumped out at me.
Yes, I know it's within specs, but long ago I determined that the published specs are way too wide (with a few exceptions) - and as a general rule, the alignment needs to be within the inner half of the tolerance.
Susceptibility to mis-alignment is something tire manufacturers have been working on for as long as I can remember. Simple grooves and ribs are the least susceptible and complex patterns more so, but there are ways to have a tread pattern that is good for snow traction AND resistant to irregular wear. But as a general rule, All Terrain tires are more susceptible than All Season tires.
You really ought to get a quick alignment. Nothing fancy, but you'll get more mileage out of that set and I think it will pay for itself in the extended life.
It probably could be aligned better, but given how straight it tracks and how good the handling is, I am hesitant to have someone mess around with it to eek a few more miles out of the cheap tires, and quick alignments might be part of its tire appetite. This truck has been aligned three times in its life by two different shops (one a dealer), and has never passed 35K or so on a set of tires. These will make it that far. Worst life was 20K on the factory tires. I may get it checked to see where it's at, but I'm not holding my breath for someone to get the alignment just right to where the truck will run a set of tires for 50K miles.
