OK, before I lube it ...
by BrocLuno
7 minutes 34 seconds ago
Toyota Japan Fluid SDS
by SXE10
Yesterday at 11:28 PM
Online Oil Viscosity Selectors
by Merkava_4
Yesterday at 11:25 PM
Considering a differential swap
by buck91
Yesterday at 10:18 PM
HVAC Evaporator Cleaning Results
by sleddriver
Yesterday at 09:51 PM
Car Acronyms
by Marco620
Yesterday at 09:46 PM
Vibration with new tires - your thoughts
by Bandito440
Yesterday at 09:41 PM
Carpet cleaning methods.
by Run
Yesterday at 09:26 PM
Fram XG16 4522mi 5.7 Hemi
by AntsinmyEyes
Emtrac Plus Battery
by Tapan
Yesterday at 09:25 PM
Did you know of Mr. Urban?
by CourierDriver
Yesterday at 09:19 PM
Ever Been a Successful Front Suspension Rebuild ?
by CrackyWainwright
Yesterday at 09:06 PM
peg, CornbreadMan, JoelB, alostaunau, alanwayne1908
58295 Registered Users
35 registered (CR94, bdcardinal, anonobomber, bvance554, BrocLuno, ag_ghost, 4 invisible), 990 Guests and 10 Spiders online.
58295 Members
66 Forums
250915 Topics
#3399649 - 06/17/14 09:50 AM Date codes on tires
old1 Offline
Loc: Columbus Nebraska
Just out of curiosity, what year did they start putting date codes on tires? On my old (1980) pickup, which I just buy used tires for, and my 65 mustang, which just gets used for cruise nights and shows, I can't find any numbers that could possibly be date codes. I find it on my new (2014) car, but not on any of the old ones, so just wondering how old the tires probably are?
Edited by old1 (06/17/14 09:52 AM)
#3399651 - 06/17/14 09:53 AM Re: Date codes on tires [Re: old1]
Quattro Pete Offline
Loc: Great Lakes
It's a bit more tricky with tires manufactured prior to 2000. This TireRack article has some info on this...
http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=11
'02 530i (Edge HM 10W-40)
'15 Q5 3.0T (Edge 5W-40)
#3399653 - 06/17/14 09:58 AM Re: Date codes on tires [Re: old1]
old1 Offline
Thanks
#3399668 - 06/17/14 10:27 AM Re: Date codes on tires [Re: old1]
Hokiefyd Offline
Loc: Virginia
old1, it's also possible, if the date codes appear to be missing, that they're on the sidewall that's facing in towards the vehicle. Tire manufacturers are required to put the full DOT code (including the date produced) on at least one of the sidewalls, and the full code should be on the sidewall intended to face out. So they'll be on the sidewall with a white wall or white letters, or on the sidewall that's labeled "OUTSIDE" for an asymmetrical tire. But for a symmetrical blackwall tire, with two sidewalls that are the same, the date code may be facing in.
Cheers,
Jason
2009 Honda Ridgeline RTL
2005 Acura MDX Touring
#3399718 - 06/17/14 11:44 AM Re: Date codes on tires [Re: old1]
eljefino Offline
Loc: ME
27th week of 1995. The little triangle means it's from the 1990s. IIRC lacking a triangle makes it the 80s, and 4 digits = 2000+.
From my collection.
If they're trying for looks on your mustang they probably put all the boring stuff on the inside, on purpose.
#3399759 - 06/17/14 12:34 PM Re: Date codes on tires [Re: old1]
CapriRacer Offline
Loc: Somewhere in the US
And to answer the original question.
The law goes back to the late 1960's. I'm sure there was a transition period, but I can't tell you when the drop dead date was - but by the time I started working in the tire industry (1971), it was fully implemented everywhere.
And, yes, if you don't find the DOT code or only a partial, look on the other side of the tire. Prior to 2008, when it was mandated that a full code had to be on the side intended out and the other had to have a partial, it was only required on one side and usually that was the side intended in.
CapriRacer
Visit my web site: www.BarrysTireTech.com
#3399792 - 06/17/14 01:13 PM Re: Date codes on tires [Re: old1]
old1 Offline
That is probably why I couldn't find it, I am sure they are prior to 2008, and they are whitewalls, so must be on the inside. Next time I have the car up for service, I will see what it says on the inside. Not that it really matters to me of course, as long as they go around I will run them. I was just curious. Thanks
#3403462 - 06/21/14 11:51 PM Re: Date codes on tires [Re: old1]
sxg6 Offline
Loc: CT
I actually ran into this problem myself, I had trouble locating the date codes on two sets of tires for my fathers 4runner. On a set of yokohama's from 2009, and a set of bridgestones from 2011, the date codes were molded into the interior sidewall of the tires.
