ALOHA jkhawaii!!! IMO, moly is a waste of time. You will not normally be able to keep it in suspension, and it's main use is as a boundary (read dry) lubricant for when an oil film is not present to keep moving parts separate. Weapons used by people don't have sufficent loads imposed on moving parts to require something with as much film strength as MoS2. If you need to lube a pistol slide, either Frog lube or any good #1 or #2 grease in SMALL quantities will work fine. If you need a gun oil, nothing finer than Rand CLP. If you can't or don't want that, then ATF will be a good second choice.
