Waterproof gun bag?
by 901Memphis
06/29/16 11:59 PM
Admin trash the 2 oldest VOAs I posted
by Mainia
06/29/16 11:09 PM
Atlas Copco Roto-Xtend Rotary Screw Comp Oil VOA
by Mainia
06/29/16 11:06 PM
"Global" antifreeze - contains EHA/2EHA?
by Jonzobot
06/29/16 11:03 PM
Schaeffer's# 158 Moly Pure Synthetic Comp. Oil VOA
by Mainia
06/29/16 10:41 PM
by Mainia
06/29/16 10:36 PM
My CarQuest premium filter??
by MNfarmer33
06/29/16 10:26 PM
Incandescent Light History and Metallurgy
by MolaKule
06/29/16 09:54 PM
Pass Word Changed?
by ls973800
06/29/16 09:26 PM
Best canned Mandarins
by aquariuscsm
06/29/16 09:11 PM
Super Short Commute OCI?
by randomhero439
06/29/16 09:08 PM
Good News About The Fram Ultras.. No Louvers...
by crazyoildude
06/29/16 08:57 PM
MNfarmer33, doublegarage, goatrancher, jameson223, graywolf001
58322 Registered Users
52 registered (901Memphis, CKN, carlprop, bdcardinal, 87sammy, Bandito440, 5 invisible), 1184 Guests and 11 Spiders online.
58322 Members
66 Forums
251011 Topics
#3399649 - 06/17/14 09:50 AM Date codes on tires
old1 Offline
Loc: Columbus Nebraska
Just out of curiosity, what year did they start putting date codes on tires? On my old (1980) pickup, which I just buy used tires for, and my 65 mustang, which just gets used for cruise nights and shows, I can't find any numbers that could possibly be date codes. I find it on my new (2014) car, but not on any of the old ones, so just wondering how old the tires probably are?
Edited by old1 (06/17/14 09:52 AM)
#3399651 - 06/17/14 09:53 AM Re: Date codes on tires [Re: old1]
Quattro Pete Offline
Loc: Great Lakes
It's a bit more tricky with tires manufactured prior to 2000. This TireRack article has some info on this...
http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=11
'02 530i (Edge HM 10W-40)
'15 Q5 3.0T (Edge 5W-40)
#3399653 - 06/17/14 09:58 AM Re: Date codes on tires [Re: old1]
old1 Offline
Thanks
#3399668 - 06/17/14 10:27 AM Re: Date codes on tires [Re: old1]
Hokiefyd Offline
Loc: Virginia
old1, it's also possible, if the date codes appear to be missing, that they're on the sidewall that's facing in towards the vehicle. Tire manufacturers are required to put the full DOT code (including the date produced) on at least one of the sidewalls, and the full code should be on the sidewall intended to face out. So they'll be on the sidewall with a white wall or white letters, or on the sidewall that's labeled "OUTSIDE" for an asymmetrical tire. But for a symmetrical blackwall tire, with two sidewalls that are the same, the date code may be facing in.
Cheers,
Jason
2009 Honda Ridgeline RTL
2005 Acura MDX Touring
#3399718 - 06/17/14 11:44 AM Re: Date codes on tires [Re: old1]
eljefino Offline
Loc: ME
27th week of 1995. The little triangle means it's from the 1990s. IIRC lacking a triangle makes it the 80s, and 4 digits = 2000+.
From my collection.
If they're trying for looks on your mustang they probably put all the boring stuff on the inside, on purpose.
#3399759 - 06/17/14 12:34 PM Re: Date codes on tires [Re: old1]
CapriRacer Offline
Loc: Somewhere in the US
And to answer the original question.
The law goes back to the late 1960's. I'm sure there was a transition period, but I can't tell you when the drop dead date was - but by the time I started working in the tire industry (1971), it was fully implemented everywhere.
And, yes, if you don't find the DOT code or only a partial, look on the other side of the tire. Prior to 2008, when it was mandated that a full code had to be on the side intended out and the other had to have a partial, it was only required on one side and usually that was the side intended in.
CapriRacer
Visit my web site: www.BarrysTireTech.com
#3399792 - 06/17/14 01:13 PM Re: Date codes on tires [Re: old1]
old1 Offline
That is probably why I couldn't find it, I am sure they are prior to 2008, and they are whitewalls, so must be on the inside. Next time I have the car up for service, I will see what it says on the inside. Not that it really matters to me of course, as long as they go around I will run them. I was just curious. Thanks
#3403462 - 06/21/14 11:51 PM Re: Date codes on tires [Re: old1]
sxg6 Offline
Loc: CT
I actually ran into this problem myself, I had trouble locating the date codes on two sets of tires for my fathers 4runner. On a set of yokohama's from 2009, and a set of bridgestones from 2011, the date codes were molded into the interior sidewall of the tires.
