Hey guys,
I am about to embark on a valve seal replacement.
I will be feeding rope down the spark plug hole to make sure the valves don't drop.
I plan to feed it through some PCV piping. Can someone tell me what diameter the PCV pipe must be?
Since 16mm is the socket size, I assume the PCV pipe can be around 20mm or so.
What is the diameter of of the threaded part of the spark plug to know what thickness rope to use?
