ACDelco X66P
by OldEuroCarLover
Today at 12:07 AM
FL910S C&P, 4,000 miles
by cb4017
Today at 12:02 AM
Mobil 1 Full Synthetic $3.99 AR Menards
by John_K
Yesterday at 10:32 PM
Causes of steering wheel shudder
by buck91
Yesterday at 10:14 PM
Brand new Focus ST...
by Striker
Yesterday at 09:55 PM
Chevy Volt bad idea for BITOG members!
by kohnen
Yesterday at 09:22 PM
Looking for oil suggestion Chevy Express 3500 6.0L
by Goofball1205
Yesterday at 08:38 PM
What ATF? 2004 Toyota Sequoia 4WD
by ShadowSix
Yesterday at 08:35 PM
Tundra steering wheel
by RN89
Yesterday at 08:11 PM
98-02 Corolla and Oil Consumption
by mmorri16
Yesterday at 08:10 PM
How does fuel dilution affect HTHS viscosity?
by HKPolice
Yesterday at 07:58 PM
Volkswagen bets big on EV(Electric Vehicle)
by HTSS_TR
Yesterday at 07:50 PM
sledhead1, AtillatheHunk, Goofball1205, Djlmedic, BigHoss256
58926 Registered Users
22 registered (Billbert, AnthemBassMan, CATERHAM, BlueOvalFitter, Atesz792, 2 invisible), 628 Guests and 36 Spiders online.
58926 Members
66 Forums
253568 Topics
#3395555 - 06/12/14 10:41 AM Cummins KTA19, RotellaT, 4-year OCI
bulwnkl Offline
Loc: Arizona
Stationary back-up power generator. It was exercised at no-load once per week for 30 minutes. Had to run the facility once during this OCI for an hour or two, about a year and a half before the sample. Filters are as old as the oil. Now that I'm here, we're modifying our maintenance practices on this engine. 604.5 hours on the engine at sample time. Engine is ~20 years old.
Code:
Spectroscopic (ASTM D5185)
Fe	3
Cu	11
Pb	6
Al	0
Sn	8
Ni	0
Cr	0
Ti	0
V	0
Ag	0
Si	3
B	81
Ca	2970
Mg	215
P	1245
Zn	1433
Ba	0
Mo	46
Na	0
K	0
FTIR (JOAP method)
Fuel	0
Glycol	0
Nit	6
Oxi	13
Soot	5
TAN	1.26
TBN	8.21
Water    0.010%
Vis 100C	14.1
Vis 40C	102.7
VI	139
"A government big enough to give you everything you want is a government big enough to take from you everything you have." --Gerald Ford
#3396214 - 06/13/14 04:41 AM Re: Cummins KTA19, RotellaT, 4-year OCI [Re: bulwnkl]
dnewton3 Offline
Loc: Indianapolis, IN
I'm a bit lost here; are you saying the sample it 1.5 years old, or that's how long ago the full-call duty cycle ran?
The engine is 20 years old.
The engine has 605 hours on it.
The engine sees typical 1/2 runs per month, plus whatever emergeny call may come up.
What I cannot seem to quite get is how many hours on on this particular sample? The long term running average is 2.5 hours/month; that is nothing really at all. However, should there not be a run-call for several months, then a half-hour run per month is a tiny fraction of use.
Overall the numbers look OK. It's really hard to know the wear on a "per hour" basis as I'm not sure what this sample represents.
TBN/TAN is very strong and could easily go longer. Contamination is non-existent by any measure. Vis look fine.
My suggestion would be to install bypass filtration (if not there already), forgot OCIs by any means of chronology, and ONLY OCI when a sample would indicate (which in this case, shows a LOT of life left in it).
Edited by dnewton3 (06/13/14 04:44 AM)
Conventionals vs. Synthetics isn't about which is "better"; it's about which lasts longer, while assuring safe operation, in relation to cost. Any product can be over or under utilized. The same applies to filters.
Make an informed decision; first consider your operating conditions, next determine your maintenance plan, and then pick your lube and filter. Don't do it the other way around ...
#3396326 - 06/13/14 07:46 AM Re: Cummins KTA19, RotellaT, 4-year OCI [Re: dnewton3]
krismoriah72 Offline
Loc: wv
I would be more worried about the fuel than the oil.
#3396925 - 06/13/14 07:41 PM Re: Cummins KTA19, RotellaT, 4-year OCI [Re: bulwnkl]
Rob_Roy Offline
Loc: Northern, NY
Fuel dilution is often a problem with diesel generators, but that doesn't seem to be the case here. Your report looks very good.
If possible, try to run the engine under load more often. Do a web search for "generator wet stacking" and you will see what frequent short runs can do over a long period of time.
2015 Subaru Legacy 3.6
2014 Subaru Outback 2.5
1999 Ford F350, V10 workhorse
#3397111 - 06/13/14 11:48 PM Re: Cummins KTA19, RotellaT, 4-year OCI [Re: bulwnkl]
bulwnkl Offline
Loc: Arizona
dnewton, this generator is exercised _weekly_ at no load. Hours on this run are around 105 (don't have the data in front of me). I don't like this weekly no-load exercise, yet the results do not indicate a problem.
We load-banked this machine recently, and that will now be a regular occurrence. I'd like to cut line power regularly, and make the switch and generator work running the facility. However, I don't care for how certain equipment behaves in the face of that brief outage, so I haven't chosen to take this tack yet.
For those who were thinking of the fuel, I was thinking of that, too. smile The sample on it shows good cetane, distillation curve is appropriate/reasonable, no microbes, and no water. We additize it regularly against the issues we face in this application, and our approach there seems to be working.
#3398294 - 06/15/14 04:54 PM Re: Cummins KTA19, RotellaT, 4-year OCI [Re: bulwnkl]
Loc: wv
My comment was relating to the fuel having bacteria after 20 years. Ive seen an actual bloom in the bottom of my tanks after sitting for a month.. but i havent used additives to 'kill' the bacteria either.. so kudos if your additives can keep 20 year old fuel viable.
#3398442 - 06/15/14 08:06 PM Re: Cummins KTA19, RotellaT, 4-year OCI [Re: bulwnkl]
bulwnkl Offline
Loc: Arizona
The tank doesn't hold 20-years-worth of fuel. wink
We only carry 500 gallons max on-hand, and it ends up being partly replenished every couple years; more frequently now that we're going to load-bank it regularly.
#3398773 - 06/16/14 09:35 AM Re: Cummins KTA19, RotellaT, 4-year OCI [Re: bulwnkl]
dnewton3 Offline
Monthly loading is a good thing. Not only good for the engine, but also the gen-head itself.
Rather than dropping main-line power to simulate an outage, why not develop a secondary, inexpensive load system (not knowing the application, I can only speculate here ...) such a running a small tool shop for a day, or perhpas fire-pump motors for their monthly testing?
As for the UOA itself, 100+ hours on this shows things are fine. The current system seems to be working, despite the low loading.
#3399453 - 06/17/14 12:57 AM Re: Cummins KTA19, RotellaT, 4-year OCI [Re: dnewton3]
Fraser434 Offline
Loc: Chicago
The fire pump would be in bypass unless its pushing water through sprinklers...
Would have almost no load.
What kind of transfer switches do you have? i'm guessing green onan ones with 4 lights in the upper corner? Considering its an onan gen. Most likely you could perform a transfer test from the ATS at minimal risk to the rest of the facility.
The cheapest load bank would be a tub of salt water (100 gallons) with adjustable steel electrodes submerged in the salt water, cable the gen to one end and it will load it up 100% unity PF. Not OSHA approved, but used outside of america.... Thats why they make resistve air cooled load banks.
Some sites do have permanent or radiator mounted load banks, very expensive.
Edited by Fraser434 (06/17/14 01:04 AM)
