Switching from HM to conventional
PA
So yesterday I had my friendly local shop fill my Saturn with QSAD rather than Defy, which I have used in the past with good results. Quite simply, it saved $10. Also I wanted to see how the car runs on dino.
This is the first time it will run on a non-HM oil since two days after I bought it, almost two years ago. I will keep an even closer-than-usual eye on the oil consumption rate. (Mine is not bad for a Saturn S series.) Any other issues to watch out for?
Not likely you will be able to tell any difference. If the HM had stopped a leak for you, it may slowly come back, that'd be about it.
