2012 Ford Focus stick, 54k miles. I'm running Peak 5-20 Synthetic with 1 qt of 10-30 (not that it matters for this question?). When my mechanic changed the oil several changes ago, I had him NOT reset the Oil change interval just to see how far it would go: answer was about 9,500 miles in Southern California winter.
Last oil change was 5,700 miles back. I'm headed north on I5, dropping down the "grapevine:" a 6 (?) mile 7% downgrade with the car in 4th of 5, AC on high to avoid using the brakes. I'm able to maintain 65 usually down this grade in 4th. I get to the bottom, level out, drop back into 5th gear, and the Oil Change message appears. It's been a little warm in SoCal, but nothing hot, and I rarely drive over 65. Most driving is on the freeway.
Did using 4th gear (tach was about 3,500 if I recall correctly) for 6 miles make the message appear?
Any thoughts would be greatly appreciated.
