Walmart ST Full Synthetic 5W30 & 10W30 5QT $12.00
by Jonny5alive
7 minutes 43 seconds ago
Keep America's Nuclear Power Stations Running
by Shannow
Today at 12:14 AM
Lubegard Biotech,my thoughts
by Marco620
Today at 12:03 AM
Frivolous lawsuit loser pays court cost !
by HTSS_TR
Yesterday at 11:49 PM
cold seizure on a small air cooled engine?
by motor_oil_madman
Yesterday at 11:20 PM
Walmart.com PUPP 5W-20 $22.47
by mike718
Pick my oil '75 Plymouth Gran Fury 400 big block
by gallydif
Yesterday at 08:40 PM
Spark plug resistance R5 vs R6
by Ndx
Yesterday at 08:39 PM
Firestone TF2876 C&P
by holdorf333
Yesterday at 08:38 PM
Castrol High mileage or Valvoline Maxlife
by NH73
Yesterday at 08:30 PM
Got to experience cornering ABS today
by LoneRanger
Yesterday at 08:10 PM
Engine Heat Soak - What causes sluggishness
by ryan2022
Yesterday at 08:03 PM
EdandSherry, Shalmaneser, Shipmate29, garytcosta, lifteddiesel90
58332 Registered Users
28 registered (BigRalphie, alcyon, 2009Edge, bvance554, barkingspider, bdcardinal, 2 invisible), 981 Guests and 11 Spiders online.
58332 Members
66 Forums
251067 Topics
Page 1 of 2 1 2 >
#3398408 - 06/15/14 07:37 PM What grease for sway bar bushings?
garlicbreadman Offline
Loc: USA
The other day i stupidly decided to apply some 3m Silicone paste to my rear sway bar bushings(the bushings that hold the bar to the chassis). Totally disregarded that the bar is painted black from the factory so the 3m silicone lube was useless. A few days later i am getting annoying squeaks going over dips and bumps. Its very annoying. Prior to this, no noise at all.
I think what happened is that the lube glazed up between the bushing and sway bar and is causing the squeak. I sanded down the glaze from the bushing and sway bar. Im 1000% sure it is these bushings causing the noise. The bushings are rubber and the sway bar is painted BLACK from the factory. Anyone know of any rear sway bar bushing lube that mixes well with rubber bushings and the black paint of the sway bar? The bushing doesnt make direct contact with the metal off the sway bar.
Edited by garlicbreadman (06/15/14 07:46 PM)
#3398429 - 06/15/14 07:54 PM Re: What grease for sway bar bushings? [Re: garlicbreadman]
Doog Offline
Loc: North Coast
The best lube is no lube.
The difference between a beer and your opinion is that I asked for a beer... well except for just now..:-)
#3398434 - 06/15/14 08:01 PM Re: What grease for sway bar bushings? [Re: garlicbreadman]
Pablo Offline
Loc: Duvall WA - Pacific NW USA
How did you apply the lube?
Did you take the bushings completely off?
Silicone grease or boat trailer bearing grease usually works fine.
#3398452 - 06/15/14 08:21 PM Re: What grease for sway bar bushings? [Re: garlicbreadman]
EdwardC Offline
Loc: Chicago, IL
I swapped out those bushings and used silicone grease with no noise yet (this was just last fall though). I've read that petroleum based grease can cause the rubber boots on caliper slide pins to expand, so I figured it might be similar for the sway bar bushings.
#3398458 - 06/15/14 08:34 PM Re: What grease for sway bar bushings? [Re: garlicbreadman]
raytseng Offline
Loc: CA
this depends, what kind of bushing you have.
If you have poly bushings, then you get poly bushing grease (e.g. prothane or energy):
http://www.prothanesuspensionparts.com/p...uoK_Z12Cb7w_wcB
Apply LIBERALLY, like 1 tube per bushing.. It actually goes on sticky like caulk but it is silicone grease.
If you have rubber bushings then no grease, but I would use the poly bushing grease as the good best alternative if you wanted to use something.
You sanded your bushings? If I were you, I'd get new bushings while you're ordering the grease if they are cheaply available and replaceable for your vehicle.
Edited by raytseng (06/15/14 08:39 PM)
#3398460 - 06/15/14 08:37 PM Re: What grease for sway bar bushings? [Re: garlicbreadman]
cpayne5 Offline
Loc: Virginia
How about a little teflon tape? A couple wraps around the swaybar keeps the poly bushings on my TSX quiet.
Edited by cpayne5 (06/15/14 08:38 PM)
#3398467 - 06/15/14 08:56 PM Re: What grease for sway bar bushings? [Re: garlicbreadman]
spackard Offline
Loc: CA
No grease is best, but PFPE-based grease doesn't have the stiction that silicon-based grease has. Expensive, but will be quiet.
Krytox 204.
#3398477 - 06/15/14 09:07 PM Re: What grease for sway bar bushings? [Re: garlicbreadman]
Merkava_4 Offline
Loc: Clovis, CA
Permatex brake caliper grease. It is a synthetic grease that looks like a green jell. You don't have to buy the big jar, you can get it in the little envelopes at Autozone in the Permatex section. Try some of that, it's good stuff.
#3398486 - 06/15/14 09:16 PM Re: What grease for sway bar bushings? [Re: Pablo]
Loc: USA
Applied a thin coat. The sway bar bracket would force all the extra lube out, so i didn't liberally add it.
#3398487 - 06/15/14 09:16 PM Re: What grease for sway bar bushings? [Re: cpayne5]
Loc: USA
wouldnt the teflon tape shred away in a matter of days?
I agree that no grease is best...but too late now. I will probably end up buying two new oem bushingsf or 5 each.
Edited by garlicbreadman (06/15/14 09:17 PM)
#3398525 - 06/15/14 09:56 PM Re: What grease for sway bar bushings? [Re: garlicbreadman]
barkingspider Online   content
Loc: socal
When I replaced the bushings on my escalade and my corvette, I wrapped the portion of the sway bar that would be covered by the bushing with Teflon tape, then I used syn valvoline grease on top of that. Then wipe off the excess. No squeaks at all.
06 Cadillac Escalade Ext
04 Chevy Silverado
13 BMW 328i (wife)
05 Toyota Camry (daughter)
02 Chevy Prizm (beater)
#3398590 - 06/15/14 11:48 PM Re: What grease for sway bar bushings? [Re: barkingspider]
Loc: USA
Sounds promising, i'll give that a shot. How long has it been now?
#3398699 - 06/16/14 07:40 AM Re: What grease for sway bar bushings? [Re: garlicbreadman]
cpayne5 Offline
Loc: Virginia
No, it will last quite a while, and costs next to nothing.
#3399120 - 06/16/14 04:45 PM Re: What grease for sway bar bushings? [Re: cpayne5]
Loc: USA
I will give this a shot tonight and report back. Did you apply any lube?
#3399178 - 06/16/14 05:53 PM Re: What grease for sway bar bushings? [Re: garlicbreadman]
PhillipM Offline
Loc: UK
None if they're rubber - the rubber is supposed to grip the bar and twist with it, so no noise, if you grease it, your noise is the bar moving in the rubber...put new bushes in, make sure it's clean, repaint the area you sanded off because spring steel is very susceptable to surface corrosion cracking, and don't grease them this time.
#3399282 - 06/16/14 08:38 PM Re: What grease for sway bar bushings? [Re: garlicbreadman]
cpayne5 Offline
Loc: Virginia
It's an aftermarket swaybar. It originally came with teflon grease (poly bushings), which lasted about two years before it became squeaky. I lived with the squeaks for about a year, then this past winter (once I installed the lift in my garage grin) wrapped the swaybar with teflon tape where the bushings engage (no additional grease). No squeaks so far after about 6 months. I've put about 15k miles on it in that time.
Edited by cpayne5 (06/16/14 08:41 PM)
#3399413 - 06/16/14 11:29 PM Re: What grease for sway bar bushings? [Re: garlicbreadman]
Loc: USA
I added teflon to the my rear sway bar and its whisper quiet now! Hope this last a while! Thanks all for your recommendations!
I also have a tsx(gave to sister) and i put a progressive rear sway bar on it and it is also squeaking. I will add teflon tape to it when i get a chance.
#3401912 - 06/19/14 11:52 PM Re: What grease for sway bar bushings? [Re: garlicbreadman]
MCompact Offline
Loc: KY
I just bought a JBR rear bar for the MS3, it comes with polyurethane bushings and brackets equipped zerk fittings. The grease they provide for installation is Super Lube NLGI Grade 2.
Mine:
2014 M235i
1999 Wrangler Sahara
1995 318ti Club Sport
1996 Speed Triple
Wife's:
2004 X3 2.5i
Son's
2009 328i
Buy what makes you smile...
#3402251 - 06/20/14 01:06 PM Re: What grease for sway bar bushings? [Re: garlicbreadman]
Quest Offline
Loc: beaver land EH?
When I replaced my 323 sway bar bracket bushings with EnergySuspension polys, they came with some very tacky/sticky silicon grease pack. I used them in my sway bar bushings (only used once during installation, no re-lubing afterwards) and they lasted for years w/o squeaking at all.
My sway bar also has paint coated on the area where the bar meets the bushings, never an issue.
Q.
"Internet discussion boards act as echo chambers for conspiracy dittoheads" A.Allen
#3402393 - 06/20/14 04:44 PM Re: What grease for sway bar bushings? [Re: MCompact]
dailydriver Offline
Loc: Bucks County, Pa.
That is exactly what UMI suggests for their Roto-Joint type rod ends as well. wink
2000 Z28 1SC 6 speed 180K miles
4L Motul 300V 0W-40, 2L Motul 300V 0W-20
M1-206 oil filter
Motul Gear 300 75W-90
Red Line D4/MTL in the T56
#3402395 - 06/20/14 04:46 PM Re: What grease for sway bar bushings? [Re: Quest]
dailydriver Offline
That is the viscous stuff made by (or for) Prothane and Energy Suspensions.
It is even made in 14 ounce grease gun cartridges as well, if you want to pay the coin for it.
M1-206 oil filter
#3402447 - 06/20/14 06:24 PM Re: What grease for sway bar bushings? [Re: dailydriver]
aquartlow Offline
Loc: Florida
I have had good luck using an anti seize lubricant like "Never Seez" on both my front and back sway bar bushings. If you have ever got some on your fingers you already know it will stay on the bushing/sway bar surface. Todd
#3456050 - 08/15/14 06:15 AM Re: What grease for sway bar bushings? [Re: garlicbreadman]
DoubleWasp Offline
Loc: Fort Lauderdale, FL
I've always just used Sil-Glyde and never had a problem.
2007 Lincoln Navigator M1 0w-40/FU
1968 Charger R/T / Supercharged 440 VR1/DBL7349
2007 Ram 3500 4x4 / Cummins 6.7 /DBL7349
2015 Porsche 911 C4S PDK
#3464302 - 08/25/14 08:16 AM Re: What grease for sway bar bushings? [Re: garlicbreadman]
ac_tc Offline
Loc: sweden
Remember to do the final tightening with the suspension loaded.
This applies to all loaded bushings in the suspension.
-98 Dodge Durango 5.9 4*4 HDEO 10w- 40 ci4
-04 PT Cruser GT 10w- 40 HDEO ci4
-Everything else HDEO 10w- 40 ci4/STOU 10w-30/THF
#3466342 - 08/27/14 01:08 PM Re: What grease for sway bar bushings? [Re: garlicbreadman]
Nayov Offline
Loc: ME
I used leftover silicone RTV (gasket maker, etc) as a lube on the sway bar bushing end links (Nissan) because I'm too cheap to buy silicone grease, but it seems to be working as the noise is gone.
#3478183 - 09/09/14 09:16 AM Re: What grease for sway bar bushings? [Re: Doog]
Bgallagher Offline
Loc: Boston, MA
+1 Why don't you just replace the bushing or the whole sway bar for that matter? You can get either pretty cheap at rockauto. You are only prolonging the inevitable if you're greasing bushings. Or try moving back to regular rubber bushings.
Edited by Bgallagher (09/09/14 09:17 AM)
2005 Chevy Equinox - 137k -Penn. HM/AC PF52 (non e-core)
2005 Chevy Malibu - 167k - Penn. HM/AC PF457G
2015 GMC Terrain - 5.3k- Delco Dexos 1 and PF457G
#3478836 - 09/10/14 12:15 AM Re: What grease for sway bar bushings? [Re: garlicbreadman]
Loc: USA
Teflon tape is holding up well, thank you for the suggestions!
Page 1 of 2 1 2 >
