2003 lesabre battery change back seat type
by snake123
05/06/16 05:43 AM
Penrite 0w-16
by toyota62
05/06/16 03:31 AM
Land Cruiser stuck in mud, rescued by hemi Jeep
by Shannow
05/06/16 02:53 AM
GM to test self-driving taxis
by xfactor9
05/06/16 01:09 AM
Resurfacing Brake Rotors
by The Critic
05/06/16 12:02 AM
Largest M1 filter for Jeep 4.0
by ARMY_Guy
05/05/16 10:50 PM
Mobil 1 or Castrol edge?
by sky06
05/05/16 09:48 PM
1 piece lug nut recommendations?
by dlundblad
05/05/16 09:07 PM
1996 Chrysler Coolant
by outoforder
05/05/16 09:02 PM
Hat Tip to RMEuropean
by sleddriver
05/05/16 08:54 PM
Toro OHV considered flat tappet type...
by Duffyjr
05/05/16 08:48 PM
Tire Rack now carries the Falken Azenis RT615k
by slacktide_bitog
05/05/16 07:30 PM
waldawg, Defcon, drivingaford, funkyheff, Ralph62
57814 Registered Users
41 registered (Best F100, billt460, bullwinkle, Atesz792, Abakev, Boomer, 3 invisible), 0 Guests and 1 Spider online.
57814 Members
66 Forums
248538 Topics
Page 1 of 3 1 2 3 >
#3398218 - 06/15/14 02:37 PM 2000 Saturn SL2 Buring Oil, a Cheap$ Fix ?
Scanoe Offline
Loc: Minnesota
I noticed a few weeks ago my 2000 Saturn SL2 is starting to have a small amount of noticeable Oil Smoke from the Exhaust.
I do know it is a common problem of Saturns to burn oil. I do not know what part of the Engine is the Problem. My SL2 is a DOHC 4-Cylinder 1.9Liter.
Is there a Cheap$ Fix to this such as an Oil Additive or Special Oil ?
Thanks in Advance
#3398222 - 06/15/14 02:44 PM Re: 2000 Saturn SL2 Buring Oil, a Cheap$ Fix ? [Re: Scanoe]
01_celica_gt Offline
Loc: St. Louis, MO
Well when you say "fix" a rebuild will do but depending on your mechanical capability it can be expensive.
Oil & additives won't be a fix.
You can try "snake" oils, no idea if they work, I just rebuild my engines if they burn oil because I dislike oil burning to another level.
Red/Black 01 Celica GT 1ZZ-FED(Rebuilt @ 211/144) @ 211/145k
Red 02 Corolla S 1ZZ-FED(Rebuilt @ 140k) @ 141k
All Autos!
#3398225 - 06/15/14 02:50 PM Re: 2000 Saturn SL2 Buring Oil, a Cheap$ Fix ? [Re: Scanoe]
mattwithcats Offline
Loc: Virginia
Try running Mobil 1 Turbo diesel or Shell T6 5W-40 for 500-1000 miles.
Lots of detergents in these oils, may unclog the rings, which is the problem.
Edited by mattwithcats (06/15/14 02:50 PM)
2009 Smart Pure
Pennzoil Platinum Euro 0W-40
Purolator Synthetic PSL 14610
175/55R15 tires...
#3398228 - 06/15/14 03:06 PM Re: 2000 Saturn SL2 Buring Oil, a Cheap$ Fix ? [Re: Scanoe]
dave5358 Offline
Loc: North Bend
Originally Posted By: Scanoe
I noticed a few weeks ago my 2000 Saturn SL2 is starting to have a small amount of noticeable Oil Smoke from the Exhaust. I do know it is a common problem of Saturns to burn oil. I do not know what part of the Engine is the Problem. My SL2 is a DOHC 4-Cylinder 1.9Liter. Is there a Cheap$ Fix to this such as an Oil Additive or Special Oil?
You might try adding Molybdenum Disulfide to your oil - a product like Liqui Moly MoS2 Anti Friction 2781 or Mister Moly Engine Oil Supplement. Both products are sub-micron size MoS2 particles in an oil suspension. Over time (maybe 500 miles), the MoS2 will attach itself to your rings and cylinder walls creating a better seal and thereby reducing oil consumption past the rings. There are other benefits - read the Liqui Moly product page - but reduced oil consumption is a likely result. Follow the label directions - basically 1 bottle per oil change. You will need to continue using it - although you may be able to reduce the dosage - perhaps to 1/2 bottle of L-M Anti Friction per oil change. Some of it drains out with an oil change - some stays behind. This product is very dark gray in color - almost black - and will turn your oil a similar color.
Most NAPA stores stock the Liqui-Moly product (or they can order it) or buy it online. You may be able to buy a similar product in 4-oz one-use tubes under the Dow-Corning trade name Molykote from a local VW dealer.
2006 Forester XT
2008 Corolla LE
#3398230 - 06/15/14 03:07 PM Re: 2000 Saturn SL2 Buring Oil, a Cheap$ Fix ? [Re: Scanoe]
901Memphis Offline
Loc: Northern Kentucky
Lubromoly motor oil saver is one of the very few additives I would put in my oil hole for something like this. If thus doesn't work you can minimize consumption by moving up to a 10w40 high mileage like Maxlife or Defy.
http://www.amazon.com/gp/aw/d/B003U4QILS?pc_redir=1402649160&robot_redir=1
Running a synthetic might not be a bad idea either if you can't find the motor oil saver. Mobil 1 0W40 European Formula for $25 per 5 quart jug at Walmart would be a perfect yearly fill for Minnesota and should burn slower than 5w30.
2002 Buick Century 125k - Built 4T65e(Maxlife) - M1 0w40 /Fram Ultra XG 3387A
1998 Nissan Altima 335k - 5MT - M1 HM 5w30/Fram Ultra XG7317+MOS+ATP 205
#3398235 - 06/15/14 03:13 PM Re: 2000 Saturn SL2 Buring Oil, a Cheap$ Fix ? [Re: Scanoe]
OneEyeJack Offline
Loc: S California
Sell it.
#3398238 - 06/15/14 03:21 PM Re: 2000 Saturn SL2 Buring Oil, a Cheap$ Fix ? [Re: 901Memphis]
dave5358 Offline
Loc: North Bend
To avoid any (more) confusion, the Lubro-Moly folks changed their name to Liqui-Moly a few years ago. Same company, same products, new name. Some of the 'old name' products are still for sale.
'High mileage' oils may help - they also contain additives which might aid in reducing oil consumption.
I'm not sure what weight(s) oil is recommended for your vehicle, but try to stay with it. If you use a heavier oil weight in the hopes of reducing oil usage, it simply makes your engine less efficient. It might be cheaper to keep adding oil.
2006 Forester XT
2008 Corolla LE
#3398239 - 06/15/14 03:24 PM Re: 2000 Saturn SL2 Buring Oil, a Cheap$ Fix ? [Re: Scanoe]
901Memphis Offline
If it's not more than a quart in 1,000 miles, I'd probably just keep topping up with api sn conventional.
#3398247 - 06/15/14 03:46 PM Re: 2000 Saturn SL2 Buring Oil, a Cheap$ Fix ? [Re: Scanoe]
KD0AXS Offline
Loc: Nowthen, MN
Use whatever oil you can find cheap on sale/clearance and add as needed. That's what I do with ours.
2014 Hyundai Elantra Coupe 2.0 GDI-PUP 0W-40
2013 Jeep Wrangler JKU-PUP 5W-20
2005 Ford F-350 4x4 5.4-Maxlife 5W-20
2000 John Deere 425-Rotella T6
#3398252 - 06/15/14 03:57 PM Re: 2000 Saturn SL2 Buring Oil, a Cheap$ Fix ? [Re: Scanoe]
901Memphis Offline
If it gets bad enough you can always grab some sae 70 motor oil.
#3398257 - 06/15/14 04:03 PM Re: 2000 Saturn SL2 Buring Oil, a Cheap$ Fix ? [Re: 901Memphis]
HTSS_TR Offline
Loc: Lake Forest, CA
Lubro-Moly/Liqui-Moly Motor Oil Saver is very good at reduce/stop small leak, it stops a leak in my E430 after 300-400 miles. It costs about $6-7 at NAPA so it's cheap enough to try.
'00 MB E430
'04 Honda S2000
'06 Volvo V70
'14 Honda Accord LX
"Throwing food away is like stealing it from the poor and hungry" Pope Francis
#3398260 - 06/15/14 04:07 PM Re: 2000 Saturn SL2 Buring Oil, a Cheap$ Fix ? [Re: Scanoe]
Olas Offline
Loc: Manchester, England
If its leaking past the rings a thorough clean might unstuck them, if the leak is past the valve stem seals you need to rebuild/replace your head.
Does it smoke more at startup, or do you see the smoke when driving along and then quickly open the throttle?
1982 VW Scirocco
1457cc
98 bhp
78000 miles
Redline fluids
Mann/Mahle filters
#3398268 - 06/15/14 04:22 PM Re: 2000 Saturn SL2 Buring Oil, a Cheap$ Fix ? [Re: Scanoe]
NHGUY Offline
Loc: USA
What about "Restore"? Its supposed to seal scratches and grooves in cylinder walls.Kind of a last chance type product.
#3398273 - 06/15/14 04:25 PM Re: 2000 Saturn SL2 Buring Oil, a Cheap$ Fix ? [Re: Scanoe]
ram_man Offline
Loc: southern mo
Nothing short of a rebuild will fix a fixed orfice pcv and a 15 40 will slow it down. It's very common and itll run like that indefinitely.
2015 dodge dart se rallye package
1995 Dodge ram 1500 5.9l
2003 chrysler pt cruiser
#3398328 - 06/15/14 06:03 PM Re: 2000 Saturn SL2 Buring Oil, a Cheap$ Fix ? [Re: NHGUY]
901Memphis Offline
Restore will plug the filter with soft metals, which might band aid the problem, but the oil burning isn't life threatening unless ran low.
Page 1 of 3 1 2 3 >
