Mobil 1 oil filter quality
by dgunay
02/09/16 03:34 PM
help replacing door pins on a 98 corolla
by ziggy
02/09/16 03:26 PM
Bought an oil filter today.
by Taildragger
02/09/16 03:14 PM
15' Audi A4 quattro 2.0T Valvoline 0W40 7510 miles
by skyactiv
02/09/16 02:53 PM
Dodge Grand Caravan - Need Some Info
by Nick1994
02/09/16 02:47 PM
Oil for 1997 4runner with 300K
by claluja
02/09/16 12:54 PM
2003-2009 Lexus GX 470 Rear shocks for sale
by exman123
02/09/16 12:09 PM
Maintenance on a Mint Low Mileage 2001 S2000
by Thugzy
02/09/16 11:54 AM
AutoZone Game...cash and gift cards
by eddielasvegas
02/09/16 11:51 AM
Dual platinum and iridium sparkplugs vs. standard
by DrRoughneck
02/09/16 11:31 AM
Kendall Super-Dxa 15W-40 SynBlend
by 2015_PSD
02/09/16 10:05 AM
2015 Ford F-250 6.7L MC Filter (9,800 miles)
by 2015_PSD
02/09/16 10:01 AM
paulp, ATLjunkcars, jqgz, ukpdxwrx, TerrenceRocks
56865 Registered Users
100 registered (2009Edge, 2015_PSD, 901Memphis, 01_celica_gt, 440Magnum, 97K15004WD, 10 invisible), 1656 Guests and 101 Spiders online.
56865 Members
66 Forums
244453 Topics
Page 2 of 3 < 1 2 3 >
#3398350 - 06/15/14 06:47 PM Re: 2000 Saturn SL2 Buring Oil, a Cheap$ Fix ? [Re: Scanoe]
eljefino Offline
Loc: ME
+2 on the 15w40. Thick won't help slow it but for some reason the 15w40 burns "better" in so far as not pulling octane, knocking, and pulling power. This from my own s-series fleet experience.
Also run a long filter on it, b/c "why not". FL400s/ P20195/ 3600.
#3398397 - 06/15/14 07:28 PM Re: 2000 Saturn SL2 Buring Oil, a Cheap$ Fix ? [Re: Scanoe]
spasm3 Offline
Loc: out there
Its low tension rings for fuel economy. Some also say its in part to not enough drainback holes in the piston , coking the ring lands. If you have a saturn not burning oil like my '02 id use pennzoil ultra. If its already burning oil, then a high mileage 30 wt. 10w 30 in summer and 5w 30 hm in winter. If it really starts going through it, then the 15w 40 summer. When my son's 01 needs a clutch , we are going to rering/rebearing it with a valve job.
Edited by spasm3 (06/15/14 07:29 PM)
13 elantra 39k 5w30 ultra
03 chevy avalanche64k pyb
02 saturnsc1 62k 0w40 castrol
01 saturnsc1 185k being rebuilt
93 ciera 71k 5w30mc5k
#3398433 - 06/15/14 08:01 PM Re: 2000 Saturn SL2 Buring Oil, a Cheap$ Fix ? [Re: Scanoe]
Doog Offline
Loc: North Coast
I would do two things:
1. replace the pcv valve.
2. switch to maxlife.
The car is already 14 years old. Not worth a repair and all of the snake oil additives really are a waste of $$.
Edited by Doog (06/15/14 08:02 PM)
The difference between a beer and your opinion is that I asked for a beer... well except for just now..:-)
#3398450 - 06/15/14 08:18 PM Re: 2000 Saturn SL2 Buring Oil, a Cheap$ Fix ? [Re: Scanoe]
umungus1122 Offline
Loc: PA
Have you tried a piston soak with MMO or Kreen?
Saturn piston soak
"Just walk away, and I promise you safe passage out of the wasteland."
'95 Chevy 1/2t 305 200k - Mobil semi-syn 7500 5w-30, Motorcraft filter
#3398457 - 06/15/14 08:34 PM Re: 2000 Saturn SL2 Buring Oil, a Cheap$ Fix ? [Re: umungus1122]
spasm3 Offline
Loc: out there
Saturn piston soak
I have tried those in the past with b-12 and mmo, they won't work.
#3398616 - 06/16/14 02:09 AM Re: 2000 Saturn SL2 Buring Oil, a Cheap$ Fix ? [Re: Doog]
Olas Offline
Loc: Manchester, England
Wow doug you must have a whole boat load of cash to suggest a car isn't worth repairing.. its sure as heck. Lot cheaper to repair a car you already own than to go out andbuy a new one..
1982 VW Scirocco
1457cc
98 bhp
78000 miles
Redline fluids
Mann/Mahle filters
#3398629 - 06/16/14 03:51 AM Re: 2000 Saturn SL2 Buring Oil, a Cheap$ Fix ? [Re: spasm3]
Olas Offline
Saturn piston soak
They might not have worked in the particular instance when you tried.them but thats not to say they wont work. Many on here including myself have had great results unsticking rings with a piston soak. Some use MMO, others prefer berrymans, diesel, brake cleaner or other strong chemicals..
More compression and less consumption can only be a good thing, and for the low cost and ease of trying its really stupid not to.
1982 VW Scirocco
1457cc
98 bhp
78000 miles
Redline fluids
Mann/Mahle filters
#3398661 - 06/16/14 06:32 AM Re: 2000 Saturn SL2 Buring Oil, a Cheap$ Fix ? [Re: Olas]
mkosem Offline
Loc: OH, US
Saturn piston soak
These cars have a very specific, well documented, issue responsible for their oil burning. Conventional wisdom is lost on them. The issue was fixed in the 02 model year IIRC. This guy has it right:
--Matt
#3398772 - 06/16/14 09:35 AM Re: 2000 Saturn SL2 Buring Oil, a Cheap$ Fix ? [Re: mkosem]
Rhymingmechanic Online   content
Loc: VA
--Matt
Correct that piston ring design causes the Saturn oil consumption.
The first thing I would do is change the PCV valve and then determine just how much oil you're burning--how many miles per quart. (Also make sure to fix any possible leaks.) If that's reasonable, like maybe 1000 miles/qt or more, try a synthetic known for cleaning.
If the oil consumption is more extreme, synthetic is going to get expensive. In that case, use the cheapest dino you can find and keep it topped up.
I married into a '94 that was using a quart in 500 miles. It progressed to one quart per 200 miles. It drank 15-40 as readily as 10-30. I used Restore, Auto Rx, MMO, Seafoam smokeouts, and piston soaks with no improvement. (Who knows--maybe all that stuff even accelerated the consumption. It sure cost more time and money than cheap dino.)
I finally settled on the "cheapest dino 10W-30 available" program. At one time, that meant 49 cent Chevron from Kragen. Those were the days for a Saturn driver! Most recently before I got rid of the car, Pepboys had a $1/quart Peak deal.
#3398875 - 06/16/14 12:02 PM Re: 2000 Saturn SL2 Buring Oil, a Cheap$ Fix ? [Re: Scanoe]
spasm3 Offline
Loc: out there
I bought a bunch of the nextgen high mileage when it was $5.00 for 5 quarts. I cleaned a few shelves of it i have around 40-50 quarts of it for the 01 saturn.
#3399155 - 06/16/14 05:20 PM Re: 2000 Saturn SL2 Buring Oil, a Cheap$ Fix ? [Re: Rhymingmechanic]
mkosem Offline
Loc: OH, US
--Matt
I had a '94 also. Always saw the best running and least oil consumption with Mobil 1300 Super 15w-40. Even had it analyzed: http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=220521
--Matt
#3401151 - 06/19/14 01:26 AM Re: 2000 Saturn SL2 Buring Oil, a Cheap$ Fix ? [Re: Scanoe]
Scanoe Offline
Loc: Minnesota
Thanks for All the Replies so far.
Turns out this Saturn also has an Oil Leak. Atm I'm looking into finding where the Leak is and how best to repair it. Figure I'll repair the Leak before I proceed any further into the Consumption Problem
#3401777 - 06/19/14 08:28 PM Re: 2000 Saturn SL2 Buring Oil, a Cheap$ Fix ? [Re: Scanoe]
mkosem Offline
Loc: OH, US
Mine developed a rear main seal leak somewhere in the 150k miles range. Ended up being a rear main seal, and I never did fixing that engine. I did later swap in a twin cam engine at ~185k that burned even more oil than the stock TBI SOHC engine though :-P
--Matt
#3403450 - 06/21/14 11:24 PM Re: 2000 Saturn SL2 Buring Oil, a Cheap$ Fix ? [Re: 901Memphis]
NeuroticHapiSnak Offline
Loc: Minnesota
Originally Posted By: 901Memphis
If it gets bad enough you can always grab some sae 70 motor oil.
Bad idea. Gear oil contains EP/AW additives than can become corrosive when used inside an engine.
2011 Toyota Yaris QSUD 5w30/Fram Ultra
2012 Genuine Stella 4T (Vespa P-series clone) Resolute 20w50/Hiflo Filtro
#3403528 - 06/22/14 04:52 AM Re: 2000 Saturn SL2 Buring Oil, a Cheap$ Fix ? [Re: NeuroticHapiSnak]
fordranger03 Offline
Loc: HI, USA
Motor oil
03 Ranger 3.0 - Mobil high mileage 10w30, Napa Gold
09 Yaris - Napa synthetic 10w30, Fram EG, 5k oci
