Years ago, when Tribotech http://www.torquemaster.it/tribotechuk.html hit the scene, some local mechanics, one of whom I respect, did some Tribotech commercials. They said that they put the Tribotech in their engines, drove for a certain period of time (I don't remember how long), then drained the oil, and were able to drive their cars for 20 minutes, and then re-fill with new oil, all without damage.
Slick 50 used to make these sorts of claims, but they've taken their advertising in a different direction now, claiming to add horsepower or fix up old engines from the inside.
On Youtube, you can see this old video featuring Bob Eubanks of an engine running without oil, supposedly because Prolong was used: https://www.youtube.com/watch?v=tQ9-yx3NRV4 OK, anybody knows you can't drain the oil out of an engine and pour sand in it and whatnot and expect good results. So what is going on in the video?
Here is a video of an engine treated with BG MOA being run without oil: https://www.youtube.com/watch?v=U0ENyqqvZpk
There are many others, such as "Petron Plus", Bardahl, "Bell Performance Xtra Lube," "Aero Wonder Lube," and so on.
I have a couple of theories. One, an engine on an engine stand will run for a while with no load after draining the oil. Also, perhaps some of these additives deposit some sort of film that will keep the engine from seizing as quickly as it would otherwise. That's not to say that damage isn't being done, I'm sure the engines are thrown away after the demonstrations.
But that leaves the ones where someone drives a car with no oil for a period of time, then refills it with the correct quantity of oil, and things seem OK. I realize that none of these additives can provide hydrodynamic lubrication when there's no oil pressure (duh), so I don't know what I'm missing.
