I had been meaning to replace the rear valve cover gasket on my '99 Sienna and finally got around to it today. This isn't easy to replace, the intake plenum has to come off plus a bunch of other stuff (including a very annoying wire harness). But I also had a new and improved rear cover and new style PCV valve that was sitting around gathering dust that needed to be installed. I also wanted to see what that back bank looked like after all these miles.
After nearly 300,000 miles I guess I didn't know what I would find under that cover. The back bank runs very, very hot compared to the front. Now mind you, this has engine been run exclusively on synthetic oil (almost all M1) since new with an OCI average of almost exactly 5,000 miles. There was one outlier run of 9,757 once (which may have been an recording error), and for the past couple of years I have been letting the interval creep up to around 6,500-6,800 miles.
I also changed out the O2 sensors as the back sensor is nearly impossible to disconnect otherwise, plus new spark plugs. The old ones were obviously worn compared to the new ones but otherwise looked OK.
Next up is a timing belt and water pump. The exhaust (catalytic converter) is sprouting a leak and I don't know what to do about that exactly. An OEM converter is $2000 and that seems a bit much for this old girl.
