Hello everyone
I'm looking for advise on cleaning up the 327 in my 66 impala I just was given. It was parked in my uncles garage since 1976. I sprayed up the cylinders up with pb blaster let them set for a few days then replaced the carb and flushed the fuel tank. I changed the oil with kendall 10w40 and replaced the Canister oil filter. The car fired up after a little messing around but my issue is after running the car for a few runs. Just in the garage (it's not ready for the highway yet) I drained the oil again and I'm getting a lot of sludge in the filter. I pulled off the valve cover and it's not too dirty underneath so I'm assuming most of the sludge is at the bottom of the oil pan. The engine only has 72000 miles on it so I don't want to pull it out or mess with taking the pan off if I don't have to but I'm looking on advise on safely cleaning the crud out of the engine. Thanks
