I have been thinking either more PF35L's or Wix 51061. I also know that ACDelco makes a version with an ADBV, the PF1218, and Wix makes two with ADBV's, the 51060 and the 51620 (which Wix says is a "high-performance, high-pressure" version of the 51060).
This goes on my '76 C20 with a 350 that has a plugged bypass in the filter adapter.
What do you recommend (filter-wise, not unplugging the bypass
I hope Pete C. and/or Herfnerd from Wix will chime in.
