jay,
The kinematic viscosity @ 100C is obtained at a fairly low shear rate. If you look at the areas of the engine where the oil is being taxed the most, in the main bearings, between piston rings and cylinder walls and in the valvetrain area, it is being sheared at a pretty high rate. You also have some severe localized heating effects in these instances. I feel that HT/HS viscosity correlates much better to how the oil is functioning in an actual engine and to the oil pressure you will see with various formulations.
You can really spec oil on the basis of HT/HS viscosity and almost forget about the SAE grades.
TooSlick
TooSlick
