How to work dealers on price?
by Huie83
07/26/16 11:56 AM
MC FL820 6,000km's Cut Open
by Canadastang
07/26/16 11:28 AM
Loathing specific manufacturer for no reason
by FutureDoc
07/26/16 11:14 AM
Top Sirloin?
by totegoat
07/26/16 10:42 AM
Has anyone met a long distance friend?
by motor_oil_madman
07/26/16 10:21 AM
Daimler's MyTaxi
by Y_K
07/26/16 09:36 AM
Snatch trap for boat tow rope
by outoforder
07/26/16 09:20 AM
Why do people put trash in other peoples truck bed
by motor_oil_madman
07/26/16 09:07 AM
P/S calls for Dexron II or III, Maxlife OK?
by K20FA5
07/26/16 09:04 AM
2008 Honda Civic slow to start
by InhalingBullets
07/26/16 08:45 AM
Top Search Today..........
by AirgunSavant
07/26/16 08:15 AM
Oil choice for Hyundai Veloster
by Kyonic
07/26/16 08:01 AM
lowsapsdieseloil, kit2523, rfabrocini, Tobin28, r0k
58600 Registered Users
83 registered (Al, 01_celica_gt, AirgunSavant, Alfred_B, 2010Civic, ABerns, 3 invisible), 1995 Guests and 22 Spiders online.
58600 Members
66 Forums
252265 Topics
Page 3 of 3 < 1 2 3
#3397552 - 06/14/14 05:02 PM Re: Ester oil conundrum - smooth engine / rough shifts [Re: LoneRanger]
LoneRanger Offline
Loc: Midwest
It's closed but the horses already got out.
'09 Subaru Forester .........(Quaker State Syn Blend 5W30)
'16 Ducati Multistrada DVT 1200S (Spectro Platinum 15W50)
#3397573 - 06/14/14 05:38 PM Re: Ester oil conundrum - smooth engine / rough shifts [Re: LoneRanger]
KernelK Offline
Loc: PA
Guffaw! grin
#3397591 - 06/14/14 06:00 PM Re: Ester oil conundrum - smooth engine / rough shifts [Re: Ducman]
KernelK Offline
Loc: PA
Originally Posted By: Ducman
Originally Posted By: KernelK
I doubt that the factory fill was mineral. If you are interested, Shell Advance Ultra 10w-40 is available on Amazon, but is very expensive.
Why do you doubt the DUCATI factory fill is a mineral oil?
I see no reason to think DUCATI would have anything "other" than a mineral oil as a factory fill.
I personally see no legitimate reason why they would want to use a synthetic oil as a factory fill.
The main reasons are as follows.
1) It's only intended to be in the machine for 1000 kms then changed at the first service @ 1000 kms or 12months whichever occurs first. If it's overdue for it's first service, I would doubt it would ultimately go much beyond 1600 kms before it was changed, and a mineral oil would suffice.
2) It's more cost effective for them to use a Group II oil as a factory fill.
3) A mineral oil is totally suitable, and fit for purpose under the recommended Break-in operating conditions.
DUCATI states the following in the current Owners Manuals.
(Maximum 5000 rpm for the first 1000 kms. Maximum 6000 rpm for the following 1500 kms.)
Here is one indication:
http://www.ducati.com/ducati_shell_advance_.do
Ducati is a high end motorcycle manufacturer who specifically recommend Shell Advance. As such, I wouldn't think it out realm of possibility that they would have agreements to purchase Shell Advance lubricants to use in the factory.
Other high end manufacturers such as Corvette and Aston Martin, among others, deliver their products with synthetic lubes installed. Why not Ducati?
Perhaps you should forward your cost and lubricant suitability concerns to the Ducati factory.
#3398050 - 06/15/14 09:42 AM Re: Ester oil conundrum - smooth engine / rough shifts [Re: KernelK]
Mackelroy Offline
Loc: Florida /Texas
The gate is just a line on the road, there's very few oils shift badly with a good transmission, most fall within the same category plus or minus 5%.
But as mention rotella 15w40 and mobil1 hm car oil are two extremes that show an obvious difference with the clutch and shifting, between high friction and slickness.
#3399082 - 06/16/14 04:06 PM Re: Ester oil conundrum - smooth engine / rough shifts [Re: LoneRanger]
LoneRanger Offline
Loc: Midwest
Adjusted the shift lever down some and it is easier to overcome the sticky 3-2 down shift now. Still going to drain the current 7:1 Silkolene:Rotella mixture and put in a fresh fill of Silkolene. I did the math. It will reduce prior fill contamination (Rotella T) from 16 oz's down to 2 ounces. That is, there should be only around 2 oz's of left over Rotella in the mix after drain and fill with more Silkolene. Getting to a purer fill of the chosen oil gives me a warm fuzzy anyhow.
Page 3 of 3 < 1 2 3
