ALS Lab test (WIX) on '14 Can Am. Viscosity results disappointing inasmuch as BRP
claims oil changes are only required every 9000 miles! NO oil was added during this test
period and it had a fresh filter.
Have ordered some Motul 7100 to try next.
DATE SAMPLED 01-Jun-14
DATE RECEIVED 05-Jun-14
DATE REPORTED 10-Jun-14
6700 Time on unit
4000 Time on this oil
Amsoil
Syn ENG Oil
SAE 10W40 Motorcycle
Metals (ppm)
Iron (Fe) 14
Chromium (Cr) Lead (Pb) 1
Copper (Cu) 5
Tin (Sn) 1
Aluminium (Al) 10
Nickel (Ni) Silver (Ag) Titanium (Ti) Vanadium (V)
Contaminants (ppm)
Silicon (Si) 6
Sodium (Na) 32
Potassium (K)
Additives (ppm)
Magnesium (Mg) 194
Calcium (Ca) 2447
Barium (Ba) Phosphorus (P) 1037
Zinc (Zn) 1181
Molybdenum (Mo) 31
Boron (B) 21
Contaminants
Water (%) Coolant No
Physical Tests
Viscosity (cSt 100C) 10.6
Physical / Chemical
Base Number (mgKOH/g) 8.4
DIAGNOSIS
Engine wear levels appear satisfactory for first sample.
Silicon level (dirt/sealant material) satisfactory. Water
content acceptable. Viscosity low, indicating possible
addition of lighter grade oil.
Action: Please confirm grade of oil used in this
component. Change oil and filter(s) if not already done.
Resample next service interval to monitor and
establish wear trend.
6700 Time on unit
Amsoil
Syn ENG Oil
Metals (ppm)
Iron (Fe) 14
Copper (Cu) 5
Tin (Sn) 1
Aluminium (Al) 10
Contaminants (ppm)
Silicon (Si) 6
Sodium (Na) 32
Potassium (K)
Additives (ppm)
Magnesium (Mg) 194
Calcium (Ca) 2447
Zinc (Zn) 1181
Molybdenum (Mo) 31
Boron (B) 21
Contaminants
Physical Tests
Physical / Chemical
DIAGNOSIS
