So i picked up a super cool Kubota B7200 with a FEL and rear rollover box blade to help around our little ranch house in San Diego CA. The little dude runs great but I can tell the HST is getting a little tired. Once it gets up to temp if you are really working it the HST whines and loses some of its "push power" if you are working a full bucket or moving some dirt. I have changed all the fluids including the motor, transmission/hydraulics (common sump) and replaced all the filters and cleaned the hydraulic screens (both). When the fluid is cold (right at start up) it has great push power and does not whine if I am working her. When I changed the fluid I used Super Tech Hydraulic fluid I bought from Walmart which is Kubota UDT compatible per their spec. My question is, is there an additive or other brand of fluid that is thicker or better maintains its flow properties? A new HST transmission runs about 2200 dollars and if I can get by with just going to a thicker hydraulic fluid I would like to do that for the time being. Thoughts?
Nate
Nate
