PP Euro 5w40, 2014 VW Jetta 1.8T, 8250 mi.
by ryanm8
07/01/16 06:49 PM
Don't be blowing yourself up this holiday weekend
by skyactiv
07/01/16 06:40 PM
Finally
by bigdreama
07/01/16 06:24 PM
Happy Canada Day !!
by Papa Bear
07/01/16 06:12 PM
Napa July 2016 Sale - Platinum filters $7.50
by slacktide_bitog
07/01/16 06:11 PM
Menzerna Became "Jescar?"
by dkryan
07/01/16 05:32 PM
In the corn belt, non ethanol fuel is everywhere
by another Todd
07/01/16 05:13 PM
Cummins: Standpipe in fuel filter needed or not?
by Extreme-Duty
07/01/16 03:36 PM
Napa Canada, Magnatec, Delvac, Napa 15W-40
by Farmer
07/01/16 02:33 PM
Meijer 4 day sale (4th of july weekend)
by Kwuality
07/01/16 02:14 PM
Brakes for 2012 Subaru Legacy
by Picky1
07/01/16 01:56 PM
Microgreen Oil Filter 50% Off Discount Code
by kohnen
07/01/16 01:51 PM
Jennyp, dcdodge, igolfat8, makomike, Alexas
58338 Registered Users
91 registered (Berny, aprilia1, 01rangerxl, barkingspider, aquariuscsm, akcooper9, 8 invisible), 1762 Guests and 9 Spiders online.
58338 Members
66 Forums
251111 Topics
#3393469 - 06/09/14 09:11 PM pinching two pieces of sheetmetal in tight space
JHZR2 Offline
Loc: New Jersey
This is probably something very simple, but I need some ideas... I have two pieces of parallel sheetmetal, currently spaced about 1/4" apart. They are both fixed at the ends, and I want the middle to be brought together to prevent a resonance that makes noise.
So, I need something that can bring the two pieces of metal together. These are sheetmetal, maybe 22ga. The issue is that I cannot put a hole in the one piece to screw or rivet it. I need something that I can slide over the two pieces that will hold them tight. I cant really crimp or bend in place, so essentially it needs to be thin, strong, and have a gap that I can set beforehand and then push into place to hold the pieces together.
The best way to think of it is, imagine a spark plug with a gap that you can set beforehand. Imagine if I slid two pieces of sheetmetal into the gap to pinch them together. That's essentially what I need.
Thoughts on what I can get to do that? Maybe a large stainless steel washer that isnt too thick? Put it in a vice, bend it over and then nice and tight, set the gap, and then slide it over?
Do you think cutting some 20ga or similar sheetmetal and folding it into place? I dont think it would be strong enough at the fold to hold the two pieces.
Suggestions?
Thanks!
#3393499 - 06/09/14 09:40 PM Re: pinching two pieces of sheetmetal in tight space [Re: JHZR2]
Trav Offline
Loc: MA, Mittelfranken.de
Take a stainless steel disc brake hardware piece (the piece that goes under the pads on the bracket)and with tin snips cut a straight piece out of it.
Bend it over with a vice or vice grips. It will act like a spring clamp.
I use these things for all sorts of stuff.
#3393508 - 06/09/14 09:48 PM Re: pinching two pieces of sheetmetal in tight space [Re: JHZR2]
OneEyeJack Online   content
Loc: S California
Glue?
#3393532 - 06/09/14 10:08 PM Re: pinching two pieces of sheetmetal in tight space [Re: JHZR2]
JHZR2 Offline
Loc: New Jersey
Something like a binder clip, but with a much smaller opening, and without the tabs on it..
#3393596 - 06/10/14 12:24 AM Re: pinching two pieces of sheetmetal in tight space [Re: JHZR2]
expat Offline
Loc: Canada
Bend a strip of metal along it's length 'U' shaped.
Use two similar pieces of metal as a gauge to set the gap, make it a Push fit.
Fill the 'U' with silicone or JB Weld, and press bent strip over the ends of your sheet metal.
I used the same system to cover a Pinch weld on the sill of my car.
#3393650 - 06/10/14 04:32 AM Re: pinching two pieces of sheetmetal in tight space [Re: JHZR2]
Rick in PA Online   content
Loc: Southeastern, PA
Perhaps re-purpose a clip nut?
That's a Dorman part. They may have something like that at an auto parts store.
A wise man told me:
"Heat is your friend." and "Any oil is better than no oil."
#3393734 - 06/10/14 07:52 AM Re: pinching two pieces of sheetmetal in tight space [Re: JHZR2]
Pop_Rivit Offline
Loc: Midwest
It shouldn't be difficult to come up with something that would hold that together. Just find a couple of small copper compression clamps and use those.
#3393972 - 06/10/14 12:45 PM Re: pinching two pieces of sheetmetal in tight space [Re: JHZR2]
sleddriver Offline
Loc: Central Texas
Photo please....
1998 Volvo V70 T5 212,455 mi. Original Owner.
