How bad is this?
by cnl64590
02/06/16 02:21 PM
Mag1 or ST Dino: what would YOU use?
by car51
02/06/16 01:54 PM
Ustria?
by Pontual
02/06/16 11:48 AM
Georgia bans 71 oils from 29 brands
by Tom NJ
02/06/16 11:27 AM
Trying to send a Blackstone sample
by 15SilvyEcotec
02/06/16 11:10 AM
2005 Trailblazer getting a new engine
by The_Eric
02/06/16 11:02 AM
AAP: 5 qt Castrol Edge, Boss filter, $30 PP $33
by DoubleWasp
02/06/16 10:48 AM
Make own external backup?
by doitmyself
02/06/16 10:33 AM
What should I use for my next oic?
by dan_erickson
02/06/16 10:25 AM
Motul Sport Ester 5w40 vs Gulf Competition 5w40
by Brit33
02/06/16 10:12 AM
M1 0W-20 EP / 15,745 mi oci / 2004 Honda Accord V6
by vinu_neuro
02/06/16 09:58 AM
Recommend me a small 12v battery.
by dlundblad
02/06/16 09:22 AM
rsritchey, Ball9320, 06Corolla, AyPapii, JakeTheYankee
56834 Registered Users
94 registered (b1amgm47, beetleything, 05LGTLtd, 2015_PSD, Bandito440, bmod305, 6 invisible), 1913 Guests and 189 Spiders online.
56834 Members
66 Forums
244313 Topics
#3392205 - 06/08/14 01:51 PM Radiator pressure
justinf89 Offline
Loc: Hampton, VA
I've been doing maintenance on a buddys '07 explorer with the v6. I went to check the radiator and it had a lot of pressure after loosening the cap. This was after it sat overnight. I changed to coolant so I've been trying to purge the air, but it won't draw from the expansion tank.
Sound like a new cap is in order? Why wouldn't the pressure equalize overnight?
97 Explorer 4.0L SOHC - 155k - ML 5w-30/PL30001
04 Safari 4.3L - 235k - ML 5w-30/L24011
05 Silverado 6.6L DMX - 135k - Ams AME/EAO52
#3392212 - 06/08/14 01:56 PM Re: Radiator pressure [Re: justinf89]
OneEyeJack Offline
Loc: S California
Compare it with one of your cars.
84 Honda Civic wagon 5-speed, 440K+ Red Line 0w-30, Red Line MTL
03 Toyota 4Runner V8 2WD, 145K+ Red Line 0w-30, Red Line D4 & 75W85 GL-5
#3392236 - 06/08/14 02:14 PM Re: Radiator pressure [Re: justinf89]
Chris142 Offline
Loc: apple valley, ca
Is the radiator full?
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#3392247 - 06/08/14 02:32 PM Re: Radiator pressure [Re: justinf89]
Warstud Online   content
Loc: MIchigan
Make sure the air is purged from the cooling system before you suspect somethings wrong with the Rad Cap. Try jacking up the front end and running it with the cap off.
FYI: On a cold motor the Rad should be full and the expansion tank should be at the Cold mark. When the motor gets up to temperature the expansion tank should read Hot. When you shut the motor off the Rad should draw coolant from the expansion tank
until it fills up and the expansion tank should read Cold again.
#3393461 - 06/09/14 09:02 PM Re: Radiator pressure [Re: Warstud]
asand1 Offline
Loc: Oregon coast
This will only happen when the cap is not plugged
Nissan/Infinity/Mazda Manuals
1996 Maxima 310K
2008 Uplander 80K
